2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Power Liftgate Problem
Old 04-20-2009, 12:05 PM
Bornzo's Avatar
Bornzo
Bornzo is offline
I was wondering if anyone can help me. I recently purchased and programmed 2 new 5 button remotes. The issue is that the remotes will not open/close the power liftgate. All other buttons work ie: lock/unlock doors and lift gate glass. Did I do something wrong like miss a step in programming the remotes? Any help is appreciated.
Mike
Old 04-20-2009, 12:40 PM
Mud Doc's Avatar
Mud Doc
Mud Doc is offline
You're not working with one of the trucks in your sig, are you? What is this on?
Joe
Old 04-20-2009, 12:47 PM
Bornzo's Avatar
Bornzo
Bornzo is offline
Sorry forgot to update my vehicles. The vehicle in question is a 2007 Limited Expy.
Old 04-20-2009, 02:27 PM
Mud Doc's Avatar
Mud Doc
Mud Doc is offline
On my former '07 Nav and now '08, it takes two clicks of the fob button to activate the gate--both up and down. Rear window only takes one click. Hope this is the problem?
Joe
Old 04-20-2009, 03:24 PM
Bornzo's Avatar
Bornzo
Bornzo is offline
I have tried the two clicks and still does not seem to work liftgate. Everything else works except tailgate. I was wondering if I maybe programmed the remotes wrong.
Old 04-23-2009, 11:08 AM
Bornzo's Avatar
Bornzo
Bornzo is offline
Does anyone have any suggestions for the liftgate problem I am having?
Old 04-23-2009, 11:38 AM
function12's Avatar
function12
function12 is offline
Does it open automatically when you press the button on the dash?
Does it open automatically when you pull on the handle from the outside?
Maybe the lift arm is broken.
Old 04-23-2009, 11:47 AM
Bornzo's Avatar
Bornzo
Bornzo is offline
function12, yes to both questions.
Old 04-23-2009, 12:19 PM
berry1234's Avatar
berry1234
berry1234 is offline
Did you get new remotes? Did you program them yourself?
Old 04-23-2009, 12:44 PM
Bornzo's Avatar
Bornzo
Bornzo is offline
The remotes are brand new and I programmed them myself. Like I said above, all the other buttons work fine except the liftgate button.
Old 04-23-2009, 01:15 PM
berry1234's Avatar
berry1234
What happened to the original remotes? There must be a special procedure to program the lift button.
Old 04-23-2009, 06:19 PM
function12's Avatar
function12
numbers on the back of my 07 fob are:
3L7T-15K601-AB
Old 05-18-2009, 02:03 PM
Bornzo's Avatar
Bornzo
Bornzo is offline
Sorry for so long since last post. I am still having the same problem. My numbers on back of remote is 3L7T-15K601-AA. Any help is appreciated.
Old 05-18-2009, 04:05 PM
berry1234's Avatar
berry1234
Probably dealer time. If you have less than 36K it is covered under warranty.
Old 05-19-2009, 01:08 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
not a Warranty issue. sounds like you have the wrong remotes man.
my 08 Expy Limited has the "3L7T-15K601-AB" code as well.
the 3L7T-15K601-AA is for a Lincoln Navi...they both have the same buttons, but the Ford version are symbols, and the "AA" have writing instead
do you have the ones that came with the vehicles? or I'm guessing you bought it used, and they weren't there?
Quick Reply: Power Liftgate Problem
