Bronco II Ford Bronco II
Oil Level Sensor
Old 04-15-2009, 10:13 PM
BII Plow Truck's Avatar
BII Plow Truck
BII Plow Truck is offline
Oil Level Sensor
Does the aftermarket like NAPA, CarQuest, etc sell the Low Oil Level Sensor for the 2.9L BII? Or is this a Ford stealer item only?
Old 04-16-2009, 12:58 PM
kernel-panic's Avatar
kernel-panic
kernel-panic is offline
Last I recall, you had to buy the oil pan with the sensor. I have no idea if anyone, even the stealership sells them anymore. I can't seem to find a listing on any of my usual resources. Dare I ask why you're looking for one?
Old 04-16-2009, 08:35 PM
BII Plow Truck
Originally Posted by kernel-panic
...Dare I ask why you're looking for one?
I have to replace the starter, the sensor has been leaking for a while and it's there in the open with the starter removed. I run Amsoil synthetic and could leak out very fast once the gasket/sensor completely fails.
I ordered one from my local Ford dealer today.
Old 04-17-2009, 02:31 AM
kernel-panic
Yeah, I have to take a look at mine when I get back home. I figure if it'll make it until the next full oil change (I am running Amsoil now as well, and the advertised 25k / 1 year between full oil changes might be entertaining...) before it's leaking bad enough to worry about, that will work. I may order the sensor and keep it handy just in case. On another semi-related note, mine still has the original starter (unless the original owner or previous owner replaced it with Genuine Motorcraft parts) and solenoid (maybe on the latter). Only thing I have had to do with it is replace bushings, brushes, and drive gear and bolt it back in place a little more securely with some locktite. The bolts had backed out on it for some reason (probably after it had been removed and reinstalled to facilitate tightening of the oil pan bolts by the previous owner) and the drive gear got munched. Flywheel is still pretty much okay, heh.
Old 04-17-2009, 03:26 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
F2AZ6C624B .. Oil Level Sensor (F2AZ-6C624-B replaced E4AZ-6C624-A) There's no Motorcraft part number.
Fits: 1986/89 Ranger/Bronco II 2.9L / 1986/97 Aerostar 3.0L / 1990/ Ranger 3.0L.
Fits: 3.8L, 302 & 351W's installed in passenger cars from 1984 thru at least 1988 (I didn't look any further).
MSRP: $48.62 // FTEpartsguy.com price: $35.00
Old 04-17-2009, 10:12 AM
kernel-panic
Correction on my first post. The replacement oil pans that I saw listed a while back had listings for one with and one without the sensor hole. Thanks for the part # Bill, I'll check back here when it comes time to order one
BII Plow Truck
Bronco II
03-27-2017 12:51 PM
BII Plow Truck
2017+ Super Duty
96
03-25-2017 09:27 AM
DFWBII
Bronco II
16
01-29-2011 11:32 PM
techusition
Bronco II
11-15-2005 04:45 PM
jbrote47
Bronco II
03-25-2001 09:08 PM
Quick Reply: Oil Level Sensor
