Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
High Flow Muffler = Reduced Torque???
Old 01-10-2002, 02:29 PM
GA01Lightning's Avatar
GA01Lightning
GA01Lightning is offline
[updated:LAST EDITED ON 10-Jan-02 AT 03:30 PM (EST)]Have any of you guys installed an aftermarket muffler on your Lightning and noticed a DECREASE in torque?
Old 01-11-2002, 06:56 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
It is possible, if you reduce back pressure too much, but its doubtful its going to flow that much more because of the cats. What else have you done to it?
Old 01-12-2002, 09:31 PM
GA01Lightning
Nothing, except for a K&N, but that doesn't count! I don't plan on doing much more until the warranty runs out, that is if I can hold back that long!
Old 01-14-2002, 10:46 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Hmmmm.... try disconnecting the battery and turning the headlights on for about 10 minutes to reset the computer. That may help the ECU relearn the fuel curve base.
Old 01-15-2002, 07:22 AM
GA01Lightning
It's been several days now since I had the muff installed, and the truck seems to be running really good, maybe even better! If I did lose any torque, it was only a very little bit.
I thought about resetting the computer, but I didn't. BTW, that's a good idea to turn on the light switch to finish draining the remaining power! I never thought of that...
Thanks for your input!
Old 01-16-2002, 09:54 AM
fordatlast's Avatar
fordatlast
fordatlast is offline
