2002 F150 front end shake?
Old 04-13-2009, 01:24 PM
Rock2324's Avatar
Rock2324
Rock2324 is offline
Hi guy's, new member here and thought I would probe the masses on a problem I have been experiencing with my 2002 F150 ext. cab FX4 that has an intermitten violent shake that comes and goes. It seems to happen only on the highway speeds and it will shake the steering wheel violently and then subside. I had all the steering linkage checked and all seems to be fine. I have done a search and turned up a few responses of the the E-brake sticking and causing this. Would the E-brake cause the steering wheel to shake like this?
Old 04-13-2009, 07:48 PM
crustyrusty's Avatar
crustyrusty
crustyrusty is offline
where did you have the front end checked? i would do it myself, its very easy. just jack the front wheels off of the ground and shake the front wheels side to side and up and down. if you find any play, have a buddy shake the tire and look under to see what has play. or try getting a second opinion from a different shop or dealer.
Obxbornfree
09-28-2016 08:36 PM
SMS888
07-12-2016 11:50 AM
crrnchris
34
10-09-2012 06:02 PM
macallan20
2004 - 2008 F150
15
08-21-2011 03:55 PM
shall208
1997 - 2003 F150
01-18-2011 11:40 PM
Quick Reply: 2002 F150 front end shake?
