we have a 89 f250 with the 351 windsor. we have tried everything we have gas but no spark going anywhere. ignition module, coil, roter, cap, pick up coil, wires, all that is good. does anyone have any ideas??????
we put a spark plug in the coil wire to check the spark would that work
Should work.
Sounds like you have a wiring problem, maybe the SPOUT wire is shorted to ground, unplug the SPOUT at the distributor.
Do have power at the coil with a test light?
Power to the Ignition Module?
If you have power to the coil does the tach side of the coil flash when you crank it?
Also the Ignition Coil plug may be bad.
Put the spring clip on a good ground and the point back probing the connector. Note if the plug is bad even if the test light shows power the coil may not be getting it.
