Valve spring installation question
Well, I am about half way through a cam change on my 1997 F350 w/ 460 and have been able to install 12 of the new valve springs with a two jaw, screw on type valve spring compressor, but I have clearance issues with the springs closest to the firewall; 1 on the driver's side and 3 on the passenger side. The last truck I changed springs on had stud mounts for the rocker arms, but my engine has the pedestal mounts. Most of the spring compressors look like they are designed for stud mounts; I don't see anything out there that looks like the compressor in the factory Ford manual. I picked up a universal, lever type spring compressor, but I am not sure how to attach it to the rocker pedestal. I looked at one of my rocker arm seats for about a second, but I don't want to screw that up, or damage the pedestal mounts. What suggestions do you have to effectively attach the spring compressor to the rocker arm mounts? Thanks in advance for your answers.
Thanks! I ended up using a stud, washer and a nut. I did have to shorten my spring compressor about 5", but the job was doable, if not much fun...
fordbroncodave
1978 - 1996 Big Bronco
15
06-27-2019 07:59 AM
Rokcrln
59
02-25-2017 05:50 PM
Dezertracer
10-07-2012 11:34 PM
Dezertracer
05-16-2010 11:26 AM
Dezertracer
03-08-2010 09:55 PM
