F350 Axle questions, anyone got an answer.
I got an '87 F350 with the D60 front axle. And in looking at my truck (haven't measured yet) it seems my front axle is 2-3 inches wider then the back. My tires are pretty close to my fender lips and it's plain to see.
Does anyone else have this on there truck, or is mine just weird?
Also I'm thinking about putting a 14 Bolt in place of my 10.25. I just think it's a better axle and would like to before I sink any money into my 10.25. Has anyone out there done this? Any thoughts (besides why, and keep it ford)?
For those curious on the subject I also posted this question in the 80-86 forum here; https://www.ford-trucks.com/forums/8...ml#post7370590
Also I think at the same time I can get a better/wider axle width. I would like a wider rear axle and think if I can I will use a van version of the 14B it's 3 inches wider. What I don't know yet is what those total widths are compared to my 10.25
Thats pretty much the norm for 4wd vehicles. The front is wider to help improve stability. My truck is the same way with the ttb front axle.
It may be true but it doesn't make much sence, you'd think the rear as the part that carries the load should if anything be wider.
But it also means more stable.
I really kind wish my rear axle would bend, for some reason it's camberd out \--/ just a bit but it is there.
Anyway an axle bending is more about how close the springs are to the wheel. The further away, the more leverage the weight on the wheel has on the axle. Sure a wider axle with the same spring placement would be more likely to bend but it is minor and easily fixed by widening the springs.
I wouldn't bother with swapping a 10.25 for a 14 bolt. The only advantage the 14B has is the extra pinion bearing support. The ring gear size is neglible, and the 10.25 has stronger axles compared to a 14B.
The track width difference is for stability and to give a better turning radius.
Jason
Jason
You just don't see ring/pinion failures much in a 14B why would going just 1/2" bigger but getting rid of the third pinion bearing be better.
I just like all the good stuff the 14B has to offer and don't see the 80 as an improvement.
