Help on ford brakes
Help on ford brakes
I have a 69 Ford F100 Good Humor Truck. I was told everything suspension is F250.
From LMC truck I bought 2wd Wheel cyl and brake master. I have a brake booster. All drums.
I can not get the lines bled. Do I have this set up correct?
A) the master came with a new push rod. Do I need to install this?
B) is the front most master port for the rear or the front?
C) one line has a big 1/2 inch or so 3/16 line fitting, the other has a smaller one with an 1/2 inch adapter. Which port gets the adapter and which gets the direct line. Does anyone make new fittings this size?
D) on the dist block, on the front side, is the top most port to the front or rear?
Thanks for any help.
ericconn
11-14-2013 11:00 PM
1970RedF100
04-04-2013 03:28 PM
MAHinton
07-04-2005 02:30 PM
