GVCW
Old 07-06-2001, 03:43 PM
bigblue1971's Avatar
bigblue1971
bigblue1971 is offline
GVCW
Old 08-24-2001, 06:23 PM
elliott's Avatar
elliott
elliott is offline
GVCW
Can anyone give me an estimate on what my combined vehicle weight should be (max)(5th wheel camper). I have a 1989 E350 Cutaway that was customized by Cabriolet. The GVW is 11,500lbs. It has 460, E4OD, 4.10 gears & 215/85X16 tires. DRW. Thanks, Bob
Old 08-27-2001, 10:57 AM
webguyrich's Avatar
webguyrich
webguyrich is offline
GVCW
elliot,
I may be wrong, but I believe the GCWR for that setup is #18,500. You'll need to weigh your rig with a full tank of gas, tools, generator, people, and whatever else you plan on carrying in it. Then subtract this from 18,500 and that will tell you what is left for the max weight for a 5ver. But you also must watch the pin weight of your 5ver. Your pin weight and the weight of your rig can not exceed your GVWR, which you said is #11,500. Word of caution, ignore the unloaded vehicle weights on the trailer, use the GVWR. Once the 5ver is loaded, food, water, clothes, camping gear, etc., you will be close to the GVWR.
An easy way to figure out what your loaded pin weight is this...you can figure 20% of your 5ver's weight will be pinweight. So say the weight of your 5ver is #10,000, you can figure your pin weight will be #2,000.
Hope this helps.
Rich
Old 08-27-2001, 08:31 PM
bulabula's Avatar
bulabula
bulabula is offline
GVCW
I agree with Webguyrich. The owners manual for my truck (details below) list a max GCWR (w/ auto transmission) of 18.5k lbs with a trailer weight range from 3500-12500 lbs & a Max frontal area of 60 sq. ft. For altitude ops, reduce GCW by 2% per 1000 ft elevation.
Chris
'88 F350 XLT Lariat CC DRW/7.5l/C6/4.10
'93 Mustang LX 5.0l/T-5/3.55's/Flo's/pulleys/K&N/Synthetics
Nissan p/u (DC commuter)
Volvo 940
bradphx
67
01-10-2024 06:12 PM
03-09-2016 12:40 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
Roachfood
03-11-2002 10:21 PM
Quick Reply: GVCW
