Last year for "3 on the tree"
The following users liked this post:
Do you know when it was discontinued? If I had to take a stab, I'd say 1983 along with the F100.
FWIW I looked at an early to mid '80s E150 with 3 on the tree. Can't find the owner's manual for my '85 right now, or I could check that.
Possibly as late as 1987 if these sites are correct about the dates the ZF and Mazda transmissions came on line, and about the years for which they offer rebuild kits.
Rebuild kit dates here, as well as years for ZF and Mazda kits:
Ford 3, 4 & 5 speed Manual Transmission reference material, what trans do I have? - Drivetrain.com
ZF and Mazda dates here:
Domestic Truck Tranny Guide
In any case, long after 1979.
on
Well really, any F-series that doesn't have a Blue Oval in the grille, which would be 1981 and older.
1987 actually.
I did a part search and found this:
Part #: 1M7246A : COLUMN GEAR SHIFT SOCKET INSULATOR / Fits 1980-1987 F-series with 3 speed manual transmission.
This part also fits 1980-1991 with C4 or C6 auto.
A truck with a 3 speed manual after 1980 is rarer than hens teeth though.
Wow, thanks for the replies, guys!
I never knew they were made into the late eighties. I really have a nostalgic feeling about the old column shifters. And 81-F150-Explorer, you're right about them being rare, I've never seen one in anything newer than a dentside. Thanks 85e150six4mtod, those links you provided are a good reference to have! Mine is so old and sloppy, I don't even have to use the clutch to shift - except from a dead stop... I think it's kinds sad they don't make them anymore. Anybody else like these old column shifters?
Anyway, thanks to everyone who responded! That's why I love this site!
Well I care dangnabbit!
1987 actually.
1987 actually.
I bet. And if there was one, it's probably converted to floor shift from wear and tear by now.
Thanks for the info.
I have a 1980 F100, manual transmission 3 speed on the tree and had a catatrophic failure of the shift collar last week. I was stuck driving on the freeway for 50 miles as it failed when I shifted into 3rd gear. I was finally able to safety exit the freeway and getting to my mechanic. Things got worse. I discovered that the shift collar for this truck, E0TZ7228, can't be found anywhere in the country, probably the world. My research led to me to a NOS shop here in CA. The owner had a couple of collars, neither my part. However, the part D9TZ7228 he had was nearly identical except the rim top was too tall by ~3/8 of an inch and the bottom was not fluted at the bottom end to sit in the wiring harness trim cover. In sum, I took the D9 to a machine shop to trim the rim and it works fantastic. Truck now shifts as smooth as butter I was told by so-called 'experts' across the country that it could not be done, that it never work and to buy a used complete column or to convert to the floor. My momma told us 'their is no such thing as can't' and I refused to accept that the D9 couldn't be modified. The one I installed was a geninue, high-quality Ford OEM. The aftermarket D9TZ7228 can be found as ADS0765 from several vendors. So, Ford nation - never give up on your '3 speed on the tree' as solutions are possible with a little imagination and fortitude.
