valve cover baffles
In physical function - venting - no, the PCV system can suck from either side. But I think the covers have a slope to the tops that is designed to go on certain sides - parrelling the slope of the lifters. And usually the valve covers are designed to have the PCV cover on the right (passenger side). You want that in the back of the engine because that is where the drain channel for the oil in the upper head flows down to the crankcase - so it is the most direct route for venting.
I can't think of any other reason other than fit, but I'm not sure I know all the caveats either - not sure I'd fool with going different on that. I'd put the PCV on the right and filler baffle on the left.
