School me on transmissions for the 05 and up!
I'm looking to buy an 05 and up.
1. What auto trans do they have and were there any changes?
2. What manual trans is in them.
I would perfer a 3V V10 with a manual but unless I order it, it is tough to find. My price range is used. Had a 7.3 with the 6 speed ZF6, is this still the same manual trans used from 2000 to 2009, in 5.4, 6.8, 7.3, 6.0, 6.4? I've heard the torqshift is a good trans, again is it the same trans for all 05 and up gas and diesel.
I don't tow regually, however the main reason for a heavy duty truck is that I will be lifting it with 37's (and will regear 4.88's?). Will an auto last with big tires?
I did try seaching but couldn't find the info I wanted, so thanks for any input.
The V10s still come with the 6spd manual like you had in your 7.3l. The 5R110 (Torqshift) is the auto for the 05'up 3V. Its a stout trans that many here really like.
Finding a V10 truck is hard enough, but finding a V10 with a 6spd and a decent set of options is darn near impossible.
What he said is right on.
And welcome to the forums.
The 4R100 was slightly different depending on 5.4, V10 or diesel (an extra clutch somewhere, and a different clutch drum).
No idea about the 5R110, but the PCM tuning (shift points, etc) is certainly different between the engines.
Thanks, I think that answers my question. I wanted to know so, if for example I test drive an 08 5.4 auto, and I like it, then I can jump on a 05 V10 that comes up for sale. I don't want to take a long drive and find out I don't like the way it drives. Also sounds like all 05+ models are good, none to stay away from.
I just am a little cautious about auto, again I would prefer the manual, but trying to be realistic. Thanks all.
Thanks that is exactly the info I'm looking for.
I had the snap ring replaced early on because I have the snow plow prep. Truck was in the shop for a day (free of charge of course) and they replaced the snap ring. Never had a problem with it...although I only have 29k miles on it...but it has done a good 2/3 of those miles towing.
---Aaron
---Aaron
