2002 F150 Overdrive light blinking
My overdrive light is blinking off and on. When I accelerate normally, the truck starts stumbling? (dont know a better word) some, sort of like a clogged air filter or fuel filter. Any ideas. I am going to take it to a transmission shop because its a little beyond me, but dont want to get ripped off.
the blinking o/d light is like the check engine light for the transmission. Has the transmission service been done on the truck? Check the transmission fluid. The transmission does not have an air filter, but there is a transmission filter that should be serviced. Take it to a couple of different shops and see if they diagnose the same problem, it could be expensive, good luck.
I was wondering if you had that problem solved, my 2001 f250 is doing the same. Thanks.
Had that happen to me when I ran my 2000 f150 4x4 over a log and it jumped up and jammed the wiring harness along the frame rail into a U channel body mount behing the Driver front wheel. Cut and mashed most of the wires. They went to the fuel pump, rear end, back part of tranny, the the tail lights. Hooked them all together with butt connectors.
Then it would run and drive in 4x4 lo but would want to stall out in 4x4 hi like it was going in 2 gears. OD light was still flashing. Found a blown blue fuse in the front of the fuse box on the engine. That fixed it and it drove all right ever since. Someone here said you could count the blinks of the OD light and pull a code but mine was just a steady on/off blink.
If not a fuse, I'd crawl under and check the connections for rust and corrosion for the wiring connectors going to the rear end and tranny. Could have run over something and broke and mashed a wire under there. Put some dielectric grease on any connections. There might be a relay acting up somewhere.
There are some dealers around looking to take the last of your 401K plan.
Let us know what you find out to fix it.
it was just the fuse
check the fuse
Sounds like a guess... probably a wrong one.
Fuses, as a general rule, do not just blow on their own. They blow because something on the load side has pulled too much current which is almost always due to a short circuit of some kind. Chafed, pinched, burned or otherwise bare or damaged wiring is the most common concern. If you just replaced a fuse without finding the underlying reason for its opening, you'd better be prepared to get stranded down the road when the intermittent short circuit returns.
Overdrive light
Same thing occurred to my truck this past week. Fortunately, it wasn’t the transmission but a faulty CMP which Ford does not make anymore.
