Changing 92 f150 from fi to carb
Really, REALLY, REALLY! think this one over before you regress fuel control to the dark ages! If it's because you're unfamiliar with fuel injection technology, learn about it first before making a mistake and going back to venturis. Fuel injection is here to stay for many reasons, and it isn't hype.
i have a carb on my truck and love it, i can run as big of a cam as i want don't have to worry about injector wires getting wet or the computer being under water, if your in pa i'll tell you how to beat emissions if you pm me
here are two threads i commented in on all the parts you need w/ part #s and how to do it
https://www.ford-trucks.com/forums/8...carb-swap.html
(they are different threads just look the same)
i just like carbs because you can do anything with them
if your in pa i can get you around emissions just pm me it's pretty easy, and carbs are not primitive crude items what do you think the ratio of 10 sec cars with carbs to fuel injection is?---most states what i do will work but pm me
that's just stupid to replace the electronic ignition with points but an msd ignition and a carb is the way to go
