Get a winch, or Locker first?
I plan on a mild build on a 86' bronco, I figure either 31" tires, or 33"s and possibly a gear change to 4.10s if I go with 33"s. Anyway, my question is, since I have a very limited budget, should I go with a winch, not regear it and leave the axles open, or get a "lunch box" locker for the rear and regear both axles to 4.10s? Would the 8.8 be ok with one running either a 31 or 33 inch tire? Or should I look around for a 9"?
I'd say go with the locker... a winch is a great tool but its best used when your alone... (shouldt be wheeling alone) i would take some time to mount good tow hooks to your truck and invest a some good straps and then use that for recovery... you'll get way more use out of a locker then a winch.
I would suggest a winch. I've got a warn winch, and there are so many different times i've used it that having a locker wouldnt have helped me get out. Not to mention other people i've helped with it.
Lockers can't get you unstuck, they can just prolong it.
A proper winch can always save the day. (Assuming you have something to anchor to!)
i just got stuck tonight and had some buddies with me but i usually have the better off road rig so if i get stuck there is nothin that will pull me out and even with lockers i woulda just dug deeper. im going to start looking for a good winch, sick of calling around to get one or sometimes 2 good trucks lined up just to save mine plus i am usually on the top of everyones list to call for a pull so a winch would be worth it IMO
Ford-Harto, you ought to wheel with people with at least the same SIZE truck. My f-350 is much more capable than anyone I wheel with, but the main guy has a K5, if it so happens that either of us get stuck, we can get out even if it is just sheer bumper bending force.
Edit:
Now that I think about it, he's going to have his new engine in aswell as his locker next time we wheel. Thats a scary thought, a chevy outperforming me. :P
Edit:
i would put in the locker first... i've been wheeling for years and still have not bought a winch. i would also tell you to buy a locker before building up your motor, its had to go anywhere if you can't get any power to the ground.. with open diffs you will be needing to be pulled or using a winch than if you had the lockers, if you flex out a bit too much on dry ground with open diffs you just spin a tire and might need a pull, but with lockers you would just keep on moving..
I would really get both lol. The locker is going to take you to alot more places but those places you will need a winch. I would get a lock rite and a gorrlia winch. Gorrilas are nice pieces and only for $400.00 for a 10,000 its a good deal. Also $130.00 for Synthetic Rope its not a bad idea to get that either.
