1950 F1 Alignment specs
Caster Degrees = 2 1/2 minimum to 4 1/2 maximum with a maximum variation between wheels of 1/2 degree
Camber Degrees = 1/4 minimum to 1 maximum variation between wheels 1/4 degree
Toe-in Inches = o" minimum to 1/16" inward maximum
And King Pin Inclination is degrees = 8 +/- 1/4 degree.
Have fun!
Have fun!
Regardless of what the original specs were you definitely want 4 degrees caster. 6 degrees won't hurt. The originals were 2 degree. You need more or it will wander all over the road when you get up to hwy speed. Buy the wedges from mid fifty.
You need at least 1/8" toe in also.
You can't adjust the caster without bending the axle. There are almost no shops that have the tools or the knowledge to do this. Live with what you have unless it is real bad.
Ford1950f1
11-20-2011 04:41 AM
1950F-1
12-27-2004 01:35 PM
