76 2wd to 4wd conversion
Here's the deal. I've had a 76' F100 2wd since Highschool, that is in near perfect condition. I'll never be able to part with it but have always wanted a 76 highboy. To solve the problem I've located a 75' highboy (body junk) and plan to make 1 good 4wd truck out of the 2.
Here is the 1st of many questions I'll have; should I start with the 4wd frame and plan to put the 2wd frame on it or should I plan to swap all the suspensions brackets from the 4wd to the 2wd?
Since the F250 has leaf spings and the 150 has coils up front, swaping the suspension and drivetrain is not going to be an easy task. Steering and the larger x-member on the 2wd will prove to be a hassle if you dont intend to lift it over 6 inches.This is also true for the divorced transfer case. While the divorced case is the easiest to swap doing so is not the all its cracked up to be. Since the 75 has everything in tact, it will be much easier to swap cabs and sheetmetal.
With swapping the sheet metal how much additional clearance will I need for the center hump in the cab? I noticed the hump in the 4wd is higher than the 2wd.
I take it the tunnels can be swapped out to make it work then. Good news. So that and adding the clutch pedal is all I'll have to do.
countrydriven
12-04-2016 02:13 AM
dannyboy_86
05-09-2016 02:33 PM
78_f150
21
01-16-2011 04:24 AM
ChaseTruck754
51
04-16-2008 06:48 PM
