No Transmission Dip Stick?
No transmission dip stick, got the manual out, there isn't no dip stick, it said, only a tranined Ford Tech can check the transmission fluid?
It has NOTHING in the manual about what fluid, when to change the fluid, when it needs serviced.
Any additional information can you guys add?
This does not surprise me from ford most all other trucks also have a drain plug on the tranny, so now the DIY guy will have to put it up on a ramp to even check the tranny, hell even my old 03 camry has a dip stick and a drain plug about every 30K I dump the fluid and put in 4 new qts. fluid stays clean just like new
I've got a friend that works at gm that said they're about 5 years away from engines that never need oil changes....he said they've been testing them for a few years now and they're coming.....
Funny part about it with the guys that change it every 30K on the tranny....is if ford tests and designs them to go 100K in between changes....what are you gaining??? I've got a friend that changed his diff fluid at 20K miles cause thats what he's always done...put the best dino fluid back in......after i pointed out that he dumped the synthetic factory fill down the drain......just doesn't make much sense to me...
Ok.....but changing fluids and changing spark plugs when there is a known problem is different.....sure...if people are having transmissions go out at 50K miles due to fluid being burnt...change it.... but when your tranny fluid is as clean as the day it went in at 50K miles.....why waste the money....
You are right, how does the Ford tech get fluid back into transmission after he/she dumps it? So now there is a mission for us on this forum "Find The Plugs Holes" one in and one out. Then we can DIY if you so please. Chris
Ford has used no dipstick on the 5R55 trans...
To put more fluid in, you stick a tube up the smaller hole, like an enema
Sounds like a pain in the neck to me, but it keeps backyard mechanics and quickie lube idiots from overfilling the trans, adding the wrong fluid, etc.
George
...in the Ford Explorer going back to 2002 at least (also the Mustang, Ranger, etc). There is a double drain plug on the transmission. The larger hex will dump the fluid, but if you remove the smaller torx plug from the center of the large hex, there is a tube that goes up a few inches and the "full" fluid mark is when you have as much fluid in the tranny as possible without it running out of that small hole.
George
George
