When you remove the wheel, is it obvious that there is a problem with the clockspring?
I ask because I have the 51 code but do not want to change the thermal fuse until I solve the underlying problem....
On mine, no. Just a flashing 32/no horn/no cruise. You might be able to ohm out the wires with a meter to test the individual leads.
If you can master the advanced search feature, look for threads by subford concerning 51 & thermal fuse. He wrote quite a lot on troubleshooting it.
Thanks for the tips...Scndsin, I will check out what subford went through. I did some searching on it awhile back but have long since forgotten most of what I've found.
Originally Posted by Scndsin
Well I jinxed myself with this thread. Went out to crank up my 92 Mustang GT this afternoon & shake the winter cobweds out of it & what does it do?
Fashes a "13" at me & then settles down to a %@#* "51"...
That is too crazy!!.....Murphy and his friggin' laws....
Sorry to hear about that....just crappy luck!
Maybe we can compare notes later....
