2002 Powerstroke not starting but GPR seems fine
Old 03-22-2009, 12:39 PM
bldrroddy's Avatar
bldrroddy
bldrroddy is offline
I have a 2002 F-250 Powerstroke that is not reliably starting. I can get it to turn over, but generally just get a lot of white smoke and it rarely starts. It will start if I plug in the block heater for an hour pre-start. When the truck finally does start, it runs great. I recently replaced the batteries with brand new heavy duty Costco ones to no effect. The starter has a intermittent solenoid, but when it is working the starter seems to engage strongly. Here is what I have done to troubleshoot:
1) I have checked the glow plug relay. Made sure the left terminal was reading 12 volts at all times. The right terminal was reading zero with the ignition off, but 12 volts when on. Did a two minute test and saw less than a .1 voltage drop between the GPR terminals with the ignition activated and relay engaged. The relay resets after about two minutes which seems correct. The engine had sat overnight when I run this test.
2) I jumped the two terminals with a heavy gauge cable for 90 seconds with the ignition off. Then tried to start the truck. Did not seem to help.
3) I pulled the glow plug connectors from both cylinder banks and tested the resistence of all 8 plugs. I used the negative battery terminal for ground. Here I noticed something that is possibly interesting. The driver side bank's four plugs all showed 1.4 ohms while the passenger bank showed .5 ohms for it's four plugs. I would have thought a bad plug would show infinite resistance, though the .5 ohm reading seemed out of spec. Do I have a problem here? Potential bad ground on passenger side?
Any help or leads greatly appreciated!
Old 03-22-2009, 12:54 PM
surveyguy's Avatar
surveyguy
surveyguy is offline
i'm looking at a similar issue on a truck i am thinking of buying. right now i'm leaning towards the CPS, have you ever changed yours? there was a recall on them, and i've read it's a common problem.
Old 03-22-2009, 01:14 PM
bldrroddy's Avatar
bldrroddy
I would think that my truck would run rough if the CPS was the problem. Once it starts, it appears to run perfectly. I am no expert however, so you could be right. The part is kind of expensive!
Old 03-22-2009, 01:25 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
MX_Fyrcaptain is offline
When my CPS went out the truck would run fine before acting up (running rough). This went on for 2 months before the CPS failed completely.
Old 03-22-2009, 01:55 PM
surveyguy's Avatar
surveyguy
i just found a cheap deal!! i read an article by someone on these, and they stated all the differences, even the International's. well ford has a new part number, for many years of pickups, and it's only like $20.i found it online for $22 plus shipping, my local napa has it for $33. that's a lot better than a couplehundred...
ford: F7TZ-12K073-B (seems the older part number was -A)
Napa: css1103
my advice is worth about $0.02 somtimes, so research for yourself. however i'd think it's worth a try for that price.
megawatt00
52
09-25-2012 06:01 PM
ncline
12-17-2011 09:41 PM
jasvid
10-07-2007 01:26 PM
Scottie250
11-15-2006 09:11 PM
JR270
17
12-16-2004 11:26 PM
Quick Reply: 2002 Powerstroke not starting but GPR seems fine
