Voltage drop while accelerating
Hi,
Ive got an 04 F250 and when I accelerate the battery light comes on. I tested the voltage on the battery while idle and all is fine exactly 14.4 volts. However when I accelerate to about 2500 or 3000 rpm the voltage drops to 12.6 - 13.0 and then the light comes on. Water levels in the battery is fine too. Is this a battery problem or a failing alternator?
accelerate, accelerates, accelerating, accerlrate, alternator, battery, change, drop, drops, engine, f250, ford, light, v10, voltage
