Sponsored by: Real Truck
Voltage drop while accelerating
Old Mar 22, 2009 | 12:13 PM
drew1485's Avatar
drew1485
Hi,
Ive got an 04 F250 and when I accelerate the battery light comes on. I tested the voltage on the battery while idle and all is fine exactly 14.4 volts. However when I accelerate to about 2500 or 3000 rpm the voltage drops to 12.6 - 13.0 and then the light comes on. Water levels in the battery is fine too. Is this a battery problem or a failing alternator?
Old Mar 22, 2009 | 12:19 PM
dew the thunder's Avatar
dew the thunder
Sounds to me like a failing alternator. You should be able to have that tested at just about any decent local auto parts store. You could have a slipping belt too but I think you'd get other issues with that situation.
Old Mar 22, 2009 | 06:17 PM
ReAX's Avatar
ReAX
You have a diode issue in the alternator. Once thing you can check for (although the battery shouldn't allow it) is AC voltage. There should ne next to none at idle and then more as you reach where the alt has failed.
Old Mar 22, 2009 | 07:12 PM
senix's Avatar
senix
r/r alternator is in order. might as well replace the belt while you are at it.
Old Mar 23, 2009 | 09:38 PM
drew1485's Avatar
drew1485
I replaced the alternator and the belt and all is working great now. Thanks guys.
ELT
Aug 13, 2015 08:05 PM
andym
May 19, 2015 07:37 PM
money pit 69
1983 - 2012 Ranger & B-Series
Jun 19, 2014 04:01 PM
Steck804
1997 - 2003 F150
May 27, 2014 10:07 AM
money pit 69
Electrical Systems/Wiring
May 16, 2014 07:05 PM
