Whats the lifespan of a '02 2.3?
Old 03-18-2009, 12:36 AM
Dasvigo's Avatar
Dasvigo
Dasvigo is offline
I was looking at buying a 02 ranger and was sad to find it was only a L4. But before I totally dismiss it I wanted to ask about the 2.3 in it. It currently has lil over 77k on it. So if properly maintained how long do these lil motors typically hold out? Also any pros and cons or experience with these motors would be appreciated. I live about 20 miles up a kinda steep mountain and wasnt sure how the 2.3 would hold up maken that drive on a regular basis. I've owned pretty much all chevys in my life so Im unfamiliar with ford drivetrains but I do like this little ranger and want to make sure its gonna get the job done. Thanks for any info & advice
Old 03-29-2009, 07:18 AM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
One nice feature of the newer 2.3 is that is has a timing chain instead of a timing belt. On the downside the thermostat isn't sold separately but part of an entire housing that is replaced as one unit and kinda pricey. Does the truck you are interested in have a 5sp manual or an automatic? Might want to try it out to see how it handles the hills in your area prior to purchase. I can't speak for the longevity of the newer 2.3 but the older 2.3 Lima seemed to have a long lifespan.
Old 04-03-2009, 06:56 PM
Dennis D's Avatar
Dennis D
Dennis D is offline
I have 214,000 on a 92 with a 2.3
and still seems pretty strong for a 4 cyln.
Old 05-20-2009, 11:45 AM
wtroger's Avatar
wtroger
wtroger is offline
You are looking at at the Duratech 2.3 I have 109000 on my 03 with no issues. You will not pull the long hills in fifth gear. This motor needs to rev to make power and in over drive (5th) gear you are not in the power band unless you are running 80 mph. That is with 3.73 gears. if it happens to have 4.11 it would do better.
lil red ranger
4 Cylinder Engines
01-17-2009 03:23 PM
lil red ranger
1983 - 2012 Ranger & B-Series
01-06-2009 12:46 PM
Fordzilla_4X4_King
07-25-2004 06:52 AM
mpw1402
06-17-2003 11:07 AM
Quick Reply: Whats the lifespan of a '02 2.3?
