Finally a plan for my 50!
My 50 f-1 has been in moth ***** for the past few years. I had no idea what to do with it. I thought of going back stock but the truck has been modified so much that returning it to stock would be very expensive.
Since stock is out, the gloves are off and I am free to do what I want. What I do want is a late 50s early 60s era ride. I want it to have an over drive transmission, vintage but reliable power and a good margin of safety.
The Truck......
A 1950 Ford F-1 that in it's history It has had the front sheet metal replaced with a 1951. From the front it looks like a 51. From the rear it looks like a 50. Right now it has a 302 and the original top shift 3 spd. Suspension is FOMOCO straight axle.
The plan.......
New wiring EZ harness
1959 Mercury 312 with a Police interceptor camshaft with a 2300 500cfm 2bbl or a 600 cfm Holley 4bbl, the ole 1850. Headers possibly straight pipes or Smithys.
1990 AOD with a Lokar shifter that will be a dead ringer for the original top shift 3 spd.
Lap and shoulder seat belts.
Stock suspension.
Eventually power disks.
How does this sound.
The Truck......
The plan.......
Stock suspension.
It’s your plan; that fact alone makes it sound like a great plan.
<o></o>What’s more important is what’s stated in your signature, “Drive that thang”. You have a goal. Let it be your flagstick in the horizon that provides the stimulus and guidance to measure your progress.
<o></o>Plans often change; goal should not. You have the liberty to take the road less traveled. Hope to see you at the finish line.
The Truck......
The plan.......
Stock suspension.
The Truck......
The plan.......
Stock suspension.
But it is fully up to you though. If it was me how ever, I would use a 292 with a more modern performance camshaft offered, a blue thunder (i think thats the brand) 292 4V aluminum manifold, have the heads worked over some and have it backed by a Ford-O-Matic (only if gearvendors could make a overdrive/underdrive for that transmission) and installa gearvendors underdrive/overdrive on back to the rear with say 3.55:1 gearing. That gearvendors unit would change that 3spd auto into a 6 spd auto basically by splitting each gear as well as providing a overdrive to raise the 3.55:1 gearing to maybe 3.22:1 or something like that. Would have the acceleation and performance but also streetability as well as being able to go on the highway without having the 292 wound up at 4,000 rpm just to do 60 - 70 mph. But that is what I would do if it was me and cost wasnt an issue.
As have been said before its up to you but your plan sounds good though just have to warn you about the 312 being harder to find since so many of them were damaged.
But you talked about a police interceptor camshaft would that be a fomoco spec camshaft from 55-64? I would be interested in that if it would work great in a 2V 292 with 1.78" / 1.51" valves. I was just going to go back with a oem stock camshaft but a police interceptor camshaft would really give the car more get up and go I bet.
bigdavesohc
10-30-2006 08:15 PM
texan2004
13
11-17-2005 12:10 PM
vernonharris
03-27-2000 01:38 PM
