Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-16-2009, 10:38 AM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
More Leaks!
After reading a post about front axles leaking I crawled under my 08 4x2 and sure enough, with 22,000miles, the rear axle is leaking. It's leaking on the driver side of the differential and both sides of where the axle meats the wheels-sorry not a mechanic-not sure what part that is. Take a look.
Click the image to open in full size.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #2 (permalink)
Old 03-16-2009, 12:20 PM
clearnetedm clearnetedm is offline
clearnetedm is starting off with a positive reputation.
Thats the exact place mine is leaking. It's in the shop right now for the work and should have it back this afternoon and I'll report the details. They are also looking at a vibration at 100KM+ in the rear end that might be related, but I suspect that will come back "no fault found".
Although mine seemed to be leaking a little more with a small puddle in the driveway, not sure if seepage is normal at all.
  #3 (permalink)
Old 03-16-2009, 06:34 PM
Truck is back and they replaced a rear axle stub shaft seal. Guy says its pretty common on these rigs. They weren't able to find the vibration which is fine for now, might just be in my head now that I'm thinking of leaking axle's. They said bring it back if it gets any worse.
  #4 (permalink)
Old 03-16-2009, 08:24 PM
This is what mine looked like before the fix:
2008 Expedition Max 4x4 Limited
  #5 (permalink)
Old 03-17-2009, 10:28 AM
berry1234's Avatar
Now that is bad! Were your outer seal near the rotors leaking too?
__________________
  #6 (permalink)
Old 03-17-2009, 10:36 AM
No just that one for now. I'm glad I read on another thread on this or I would have never gone under to have a look. I'm going to make sure I get under there at least once a month just to keep an eye on things.
BTW this was the rear diff and the axle towards the driverside tire.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
