i have a 2008 f 450 with 19.5 factory tires , what air psi should i run in tires around town with no weight on them , its says 110 psi on tires i know thats what i will run when pulling my toyhauler , thinking it would be pretty boncey with 110 empty
With dually tires, the only thing that I've heard is not to let them rub against each other... Beyond that, I think that tire pressure is a matter of choice, especially when not towing/hauling. The tires will wear more quickly on the outside edge at lower pressures. Experiment with different tire pressures until you find the one that seems best.
