need a starter asap!
The spring is fairly easy to replace. You remover starter, make sure you hold it together or it's going come apart. Once you have it out there are two bolts that holds the spring collars to the shaft. Breaking the spring is common and good parts store like NAPA should have them. When you go in go for the oldest guy behind the counter, the young one won't have any idea of what you're looking for.
