hi all im new to this so im sorry if i do something wrong , i got a 99 expedition xlt 4.6liter 4x4 and im making it a 2wd , i kno itll be alot of work and i know ill get alot of crap from this but its cool , ive heard about a brown wire mod that if you cut this wire it will disengage your a4wd and makes is a 2wd only , well if i do this mod will i be able to take out the front drive shaft ? and eventually get a 2wd trans and front suspension parts and so on , any help is well appreciated , thanks
lookin to do a full air ride suspension and the front 4x4 crap wont be able to handle the extreme angles and so on ,., so my main and only question is if i cut the brown wire this will disable my a4wd but this done will i safely be able to take out my front drive shaft ?
but my expedition does not have a selector for 2wd only its only a4wd 4hi and 4low , what im worried about is wen the computer realizes my rear tires slipped and my t-case goes boom or something because it wants to move those front tires but wont be able to
When the PCM senses the rear tires are slipping, all the PCM will do is engage the clutch in your transfer case until the rear wheels are no longer slipping.
If you have removed the front driveshaft, the rears may just keep spinning until you are really stuck. Just carry the front driveshaft with you and if the rear wheels spin until you are stuck, just jump out and install the front driveshaft.
sweet , truck just got a oil change today and a full tune up , did a cheep exhaust to ( cut the stock out and put a straight pipe ) she sounds pretty good
Did you leave the cat in and do a pipe? I can promise you that you did not gain any power from making a 4.6L engine lose its muffler. The muffler probably was restrictive enough for you to gain any power anyway. For everyone else's sake, please put the muffler back on you 4.6L engine, it's not like you have a race car, you have a small tank.
