1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2004 Ford Expedition Service Engine Soon Light
Old 03-09-2009, 06:56 PM
aroc126's Avatar
aroc126
aroc126 is offline
2004 Ford Expedition.
engine dies when driving slow. battery light comes on when at idel, took
truck to auto zone to test it out and they could not get a read from it, they said they had a simalar prblem with another customer, and that person said they went online and they figured out it was a fuse blown somewhere but they couldn not tell me where, does anyone have any idea where i could look, so i can get my truck diagosed, by auto zone?
Old 03-09-2009, 07:09 PM
ford12508's Avatar
ford12508
ford12508 is offline
I would say if it's a blown fuse start with the fuse box. just a hunch.
Old 03-09-2009, 07:48 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Look in your owner's manual for the fuse for the OBDII test plug. It's usually the cigar lighter fuse.
If the fuse is good, the AutoZone store needs to update their scanner to a CAN protocol unit.
Steve
Old 03-09-2009, 08:21 PM
aroc126's Avatar
aroc126
aroc126 is offline
Thanks guys, the fuse was blown, i will be taking the truck tomorrow to get it checked out! I will let you know what happens, thanks again!
Old 03-10-2009, 11:11 AM
04markIII's Avatar
04markIII
04markIII is offline
fyi, i had a similar issue. turned out to be a 1" exposed piece of engine harness. hard to see as it was behind the intake manifold. the exposed wire was shorting out on the block, and would blow the fuse as i was driving.
Old 03-10-2009, 11:35 AM
aroc126's Avatar
aroc126
aroc126 is offline
Well I just got back from autozone and the code was P0320 which is for a crankshaft position sensor! How do i go about fixing this problem? Anyone?
Old 03-10-2009, 01:06 PM
04markIII's Avatar
04markIII
lol, replace the cps! i looked at the diagram, and it's right in the front engine cover. about $50 retail at dealership. probably have to have the pcm reflashed to have the code removed afterwards.
Old 03-10-2009, 06:11 PM
aroc126's Avatar
aroc126
aroc126 is offline
is there anyway you can shoot me over the diagram you looked at? I would greatly appreicate it!
Old 03-11-2009, 09:19 AM
04markIII's Avatar
04markIII
i can if you have access to a fax.
Old 03-05-2012, 11:46 AM
Rkarma's Avatar
Rkarma
Rkarma is offline
Unhappy 2000 Ford Expedition, No service engine soon light coming on
I have a 2000 Ford Expedition. I took it in for the usual smog check (CA) I had an egr valve problem, got it fixed. However, it will not pass smog because... the service engine soon light does not come on. Is there a fuse that it could be or is it more than likely the bulb is burned out?
Old 03-05-2012, 05:31 PM
projectSHO89
Since there's no fuse just for the bulb, it's likely the bulb that is burned out.
Next time, start a new thread instead of resurrecting an old, dead, and unrelated thread.
chazman
11-02-2012 06:06 PM
LastKahuna007
09-05-2011 12:42 AM
snowmobile mike
1999 to 2016 Super Duty
04-16-2011 06:37 AM
sscapricewagon
02-13-2009 12:50 PM
haroutd
16
02-24-2003 10:59 AM
Quick Reply: 2004 Ford Expedition Service Engine Soon Light
