My machinist made me a press to remove top hinge pins. It worked very well but those pins are definately in there. We ground the top flat and pressed them from top down instead of bottom up.
4thgenford-
I took the hinges off my previous 56, set the pin area over the end of a 6" length of 3/4" pipe welded to a piece of flat stock, and proceed to beat them into submission with a punch and big hammer. By the way, if you have three hands it makes it a little easier. That's why I inquired about the press being for sale.
Sure could have used that rig. I ground off the pin heads, pickled them with PB Blaster, and needed to drill mine out quite a bit before they would budge. What a work out.
do you beat on the hinge pins with the door on the cab or off? mine have been soaking in penatrating oil for a while, i need to gring the heads off but want to know how to proceed with the least amount of damage.
When I removed mine with the hammer/punch method the hinges were removed from the cab and doors. I would be repairing alot of sheetmetal if I had done that on the truck or just on the doors.
