Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 11-13-2002, 01:46 PM
jpalm jpalm is offline
Garage is empty, add now
jpalm is starting off with a positive reputation.
Post 345HP Hemi Ram vs S/C HD F-150
I know it can't take the lightning, but do you think a 4 door Hemi Ram can beat the 340HP HD F-150? I don't know who has the weight advantage and i haven't seen road tests on the Ram, but i've seen 6.2 sec. listed as the 0-60 time on the F-150. Any thoughts?
  #2 (permalink)
Old 11-15-2002, 04:06 PM
christop43's Avatar
christop43 christop43 is offline
christop43 is starting off with a positive reputation.
I would say the HD Ford would take it. The power sounds comparable, but the Ford has all wheel drive, so it would get a better start off the line.
__________________
http://www.ford-trucks.com/user_gall...oid=11701&.jpg
1990 Ford Bronco EB 351W SOLD
  #3 (permalink)
Old 11-17-2002, 06:49 PM
reddevilf150 reddevilf150 is offline
reddevilf150 is starting off with a positive reputation.
Why would you even compare the two?? They are in a totally different category. The Dodge is a 2500 HEAVY DUTY Ram, the Ford is a Supercharged, lowered, half-ton light duty truck. I would say the F-150, but then again.....they shouldn't even be compared.
Now take that Hemi, put it in a 1500, supercharge it, put on better suspension, change the looks a little bit, and it'll give the Lightning a run for its money!
__________________
Matt
95 F150: SOLD
  #4 (permalink)
Old 11-18-2002, 11:15 AM
>even be compared.
The Hemi will be put in the 1500. Thats what i was talking about. I guess i should have specified. Anyways, it will not be supercharged, but it will be put in the 1500 either this year or next.
  #5 (permalink)
Old 11-18-2002, 11:16 AM
HD stands for Harley-Davidson. It's not all wheel drive.
  #6 (permalink)
Old 11-18-2002, 01:08 PM
texan_eagle_scout's Avatar
texan_eagle_scout texan_eagle_scout is offline
texan_eagle_scout is starting off with a positive reputation.
The Ram will have 345hp / 375? lb-ft of output. The HD will have conparable HP but much more torque (425 ft-lbs @ 3,250; much more torque at a much lower RPM than the Ram). That means it will eat the Ram for lunch off the line, down the track, and anywhere else it wants. *MY* normal 5.4L in my SuperCrew produces 350 ft-lbs in stock trim. The Ram realy doesn't instill fear in my heart to be perfectly honest. It's power peaks way too late in the powerband, just like GM's gas engines. Real work is done off idle, which is how you pull a load. The "Duck" (Dodge, Get it?) has to be reliable before I give it *any* street cred.
BTW: If you ever meet a Dodge Truck powertrain engineer, ask why they used 2 plugs per cylinder. (It eliminates a dead zone in the fuel combustion. This is an inherent issue in the hemi design.)
Ford = Dodge =
__________________
Texan_Eagle_Scout
2001 XLT Screw
5.4L V8
White Ext/Grey Int
No longer in Texas, and no longer driving my truck
  #7 (permalink)
Old 11-18-2002, 04:43 PM
Tex Arcana Tex Arcana is offline
Tex Arcana is starting off with a positive reputation.
[updated:LAST EDITED ON 18-Nov-02 AT 05:44 PM (EST)]>>I would say the HD Ford would take it. The power sounds
Nope, and it's a supercharged 5.4, putting out 360hp, 425 ft-lb of torque. It *will* eat the Ram for lunch, especially if enterprising owners goout and get the Lightning lower blower pulley, which will bring it back up to the 380/450 numbers.
And remember that these numbers are *understated*...
  #8 (permalink)
Old 11-19-2002, 09:30 AM
Actually the stock supercharged HD puts out 340HP. I wish it put out 360HP. I can't wait till i can drop the lightening pully and a chip in mine. I just don't want to affect the warranty just yet.
  #9 (permalink)
Old 11-20-2002, 09:24 AM
[updated:LAST EDITED ON 20-Nov-02 AT 11:12 AM (EST)]I have been told, correct or not I don't claim knowledge on anything, that if the aftermarket parts that you install on a vehicle will maintain or increase performance over stock then the warranty won't be voided. Performance being more than just power generated, but durability, fit, function, efficiency, etc... Or that is my understanding.
If that is true using a Ford pulley from a Lightning shouldn't void your warranty. You are maintaining or increasing performance using parts of sufficient quality. Besides how many service guys would even notice the difference?
Is this line of thought full of ca-ca, or is there some truth to again, what I have been told?
__________________
Texan_Eagle_Scout
2001 XLT Screw
5.4L V8
White Ext/Grey Int
  #10 (permalink)
Old 12-22-2002, 03:57 PM
steveval14 steveval14 is offline
steveval14 is starting off with a positive reputation.
I have seen the hemi ram and it does not even compare to the hdf-150 there is no comparison to the harley, through speed, braking or sound.
  #11 (permalink)
Old 12-23-2002, 08:28 AM
2003EXPY's Avatar
2003EXPY 2003EXPY is offline
2003EXPY is starting off with a positive reputation.
My understanding of it as explained to me by a darn good service rep is mods do not void the warranty unless they are the cause of a malfunction or breakage.
__________________
[/SIGPIC]
1994 F150 Totally 100% Stock & Original
2004 DTR Mercury Marauder #2
2005 Lava Red Sunglo Harley Geezer Glide
"The Big Red Bug Killer"
  #12 (permalink)
Old 12-23-2002, 05:03 PM
Tonnny Tonnny is offline
Tonnny is starting off with a positive reputation.
I have a Ford F-150 Lightning HD Series And it is fast and has a lot of power behind it. But my dad owns a Dodge Ram Hemi and it is also fast, and it is also has power behide it.
  #13 (permalink)
Old 12-23-2002, 05:06 PM
James Hutchison My father race and HDF-150 and it was about the same but my dad got it right at the end. So both trucks are the same.
  #14 (permalink)
Old 12-23-2002, 05:08 PM
James Hutchison how about a ford f-650 it will beat the both of the trucks in any thing.
  #15 (permalink)
Old 12-28-2002, 12:35 PM
dee dee is offline
dee is starting off with a positive reputation.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
