Removing catalytic converter legal or not
#31
To the OP, Does the Vegas area require emission inspections?
#32
#35
Short answer is no. In general, newer diesels are required to have them due to the newer EPA regs since 2003. Part of the reason Ford went to the dreaded 6.0L in 2004 was to satisfy these new rules within a quick turn around time. I'm assuming that the reason you are in this forum in the first place is likely because you bought a 7.3L to avoid all those hassles with the 6.0L. The only way I would have one installed on my truck now is if the law changed and I wasn't able to register it or pass the emissions test. And then I would have it removed after the inspection ;-) (that's a joke, please don't send me anti-tree hugger messages)
#36
Just FYI my friend, this thread is over 3 yrs old.
2003, actually. Midyear during the production run.
But yeah, like you said, short answer is no.
Gas or diesel, smog equipment cannot be tampered or altered in any way. It doesn't matter if the state has inspections or smog checks.
Stewart
Stewart
#37
I'll make it easier. If the sticker in the door says NON-CATALYST that means you do not need a converter, you will never need a converter and it doesn't matter what state your in, you will not need to put a converter on your truck, It was converter exempt from the time it was built and never will need one by law. Thats like saying California is going to make you put a converter on your original 1964 Mustang with an original engine. But they will make you put a converter on your mustang if it has a post 1974 engine.
#38
Stewart
#39
Chris, you would be surprised...NV requires a cat IF the VIN comes back to a vehicle which originally was equipped with a cat. In practice, it all depends on the county of registration in Nevada...in Clark (Las Vegas region) and Washoe (Reno region) counties diesels under 14k GVCW are inspected, all other counties are exempt. This is why my truck is registered in NM...
#40
#41
Reviving and OLD thread vs starting a new one....
Here's my situation, just bought an '02 7.3 w/manual tranny from a Dealership. Vehicle was sold by the dealership on consignment. All of my paperwork on the sale states that I bought the vehicle from them (actual owner's name no where on paperwork). Live in Colorado, some counties have emissions testing while others don't.
My county does have emissions testing. Took it in to get tested yesterday, truck passed on the actual test (runs VERY clean) but upon visual inspection there was no Cat. Engine sticker says the truck has to have a Cat, truck failed as a result.
My question is this ... how culpable is the dealership for selling me a vehicle that was missing required equipment to pass emissions and thus get registered? Their story is that since they didn't actually own the truck, they never did and inspection and thus never knew about the missing Cat. Dealership has offered to split the cost with me to have a cat installed but that means i'm still coming out of pocket hundreds of dollars.
Any advice you experts can give would be great. I really feel that the dealership should pay for the entire install to make the truck right. Wasn't sure if I had a legal leg to stand on.
Thanks for listening.
#42
Received 3,118 Likes
on
#44
#45
on
