6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Oil Filter Wrench
Old 02-14-2009, 06:48 PM
leejk's Avatar
leejk
leejk is offline
Oil Filter Wrench
Hi,
Can anyone tell me where I can a tool to fit the oil and fuel filter caps of the 2008 6.4L engine? It looks like a regular 6pt socket size, but I don't have a caliper to measure it to know whether a metric vs. standard size would work. Does anyone know where the tool can be purchased or what size it is?
thx
Old 02-14-2009, 07:14 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
I have seen/read the answer to your question somewhere in these forums. I want to say it is in the 40mm range. The answer will surface before long.
Old 02-14-2009, 07:30 PM
leejk's Avatar
leejk
leejk is offline
I found one here that I think will work: Amazon.com: Lisle 14500 Oil Filter Socket: Automotive
Now I just need to find out what the torque spec is on the cap... cause it looks like it'd be easy to crack if over tightened. Anyone know what that spec is?
thx
Old 02-14-2009, 10:36 PM
hdway's Avatar
hdway
hdway is offline
The size is 36mm
Old 02-14-2009, 10:48 PM
origcharger's Avatar
origcharger
origcharger is offline
thx
3/8" drive ratchet fits that socket, "wrist" tight is plenty.
Old 02-15-2009, 01:33 AM
GregsSD's Avatar
GregsSD
GregsSD is offline
Just go down to your local Autozone and look in the filter wrench section, that's where I got mine at for about $9.
36mm 3/8 drive
Old 02-15-2009, 07:15 AM
rmosso1's Avatar
rmosso1
rmosso1 is offline
Confirming above.
I bot a 36 mm 3/8" drive shallow aluminum fuel filter socket. Sears did not have it in stock, but if you buy it at a SEARS store, they pay the freight. Mine cost $11.00 with tax.
Some of the auto stores try to talk you into buying a steel 1/2" or 3/4" drive socket. The aluminum socket is perfect.
Old 02-15-2009, 08:15 AM
stevestroke01's Avatar
stevestroke01
stevestroke01 is offline
thx
The torque specs are on both caps. I always use a 3/8 drive torque wrench and torque them to the specs on the caps just to be safe.
Old 02-15-2009, 12:46 PM
69cj's Avatar
69cj
69cj is offline
Pretty sure it's 9 foot pounds.
Old 02-15-2009, 03:58 PM
shobbs64's Avatar
shobbs64
shobbs64 is offline
The torqe specs and directions are in the box with the new filter, it is 27Nm or 18lbs-ft as listed in the napa gold oil filter with cap included, also listed on some of the oil caps. some filters do not come with the caps, however the newer production do. I hope this was a help!
Steve
Old 02-15-2009, 08:21 PM
sawtooth's Avatar
sawtooth
sawtooth is offline
yep 36mm and 18lbs-ft
Old 02-16-2009, 08:31 AM
69cj's Avatar
69cj
69cj is offline
I would not use the Napa as they are a will fit A/M filter as evidenced by the new cap and adapter. Stick with Motorcraft/ Racor / International for best results. Just my opinion but that has been backed up by many on this and other websites. Your engine and warranty will thank you.
wahfulls
Modular V10 (6.8l)
15
11-12-2015 06:12 PM
Grinder Man
1997-2006 Expedition & Navigator
10-10-2014 09:35 AM
wahfulls
Modular V10 (6.8l)
01-12-2013 11:49 PM
linus72
06-15-2012 12:06 PM
Steve_Uzi
Modular V8 (4.6L, 5.4L)
02-16-2009 04:20 PM
Quick Reply: Oil Filter Wrench
