Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 02-13-2009, 09:49 AM
DaveandJennyP DaveandJennyP is offline
DaveandJennyP is starting off with a positive reputation.
My broken exhaust manifold studs project.
I am currently working on replacing all the studs on my exhaust manifolds. I have an '03 Excursion. I have read everything on this site about doing it and thought i'd give it a try. So maybe to help someone else, here is what i have found so far:
Drivers side had one visually broke before I started. Upon taking the others out 3 more broke off and left part of the stud 1/8" below the surface of the block. I have succesfully extracted 2 of them so far.
I have to agree with "Mr. Krewet" that the studs are defective.
Passenger side had 1 broke before I started and as of now has 3 broke below the surface of the head and 2 broke with some stud sticking out.
The studs drill very easy with regular bits. (Not Stainless?)
Thankfully none broke on the bottom where the motor mounts are.
It is incredibly important to get your drill started in the center of the stud. After getting a nice hole they came right out with an extractor. Actuall the 4 on the drivers side were loose in the head. I could rotate them with a sharp instrument. Problem is the first thread or two is monkied up from the shoulder of the stud.
Updates to come as I progress.
I am planning to re-install with grade 8 hex head bolts.
Thanks for everyone for the info on this site.
  #2 (permalink)
Old 02-14-2009, 02:51 PM
I managed to get all the busted studs out this morning without damaging any threads. What a huge relief!! I had to resort to welding a nut to one stud because i broke my pilot drill off in it. I just zapped the end of the stud and built up some weld until it was above the surface of the head then held a nut up to it and filled it in. It came right out.
All in all not a bad job to do.
  #3 (permalink)
Old 02-14-2009, 04:34 PM
dew the thunder's Avatar
dew the thunder dew the thunder is offline
dew the thunder is gaining momentum as a positive member of FTE.
How long did it take you?
__________________
-Brice-
1999 V10 F250 SD XLT 4X4 4.30LS
18X9 XD Badlands, 285/65 Dune Grapplers, Doug Thorley Headers,
K&N, Chrome Grille, New headlights & corners, Bilsteins,
Clear Cab Lights, White Lightning bar, LED dome lights, SCT LiveWire
LED 3rd brake light, FM 40, SuperWinch hubs, LED Tails
  #4 (permalink)
Old 02-14-2009, 06:16 PM
m350 m350 is offline
m350 is starting off with a positive reputation.
You say some seemed loose,,,sounds like left-hand drill bits may have backed them out nicely,,,?? Did you try them ?
__________________
06' F-350 XLT SC, S-Bed, 6.0, Auto, man-hubs
04' Explorer NBX, 4.6, auto, 3:73 LS
68' Torino, 289, 4 gear
  #5 (permalink)
Old 02-14-2009, 07:09 PM
MD V10's Avatar
MD V10 MD V10 is offline
MD V10 is starting off with a positive reputation.
Quote:
I'm glad its going so well for you, I'm going to start mine soon. Where can I get left hand drill bits from?
  #6 (permalink)
Old 02-16-2009, 05:57 AM
Quote:
I have 6 hours into getting everything removed. I am waiting on some grade 10.9 flange head 8-1.25 x 35 mm bolts so I can put it all back together.
I only used left hand drill bits. Problem is the first thread or two is messed up a little from the shoulder of the original studs so it took a fair anount of torque to get them passed those threads.
Quote:
My local True Value had left hand bits.
  #7 (permalink)
Old 02-17-2009, 09:42 AM
Update:
I checked my manifolds on a granite surface plate at work the other day. The drivers side was within .004" of being flat. The passenger side was flat as well except the one port at the front (opp. collector) which was up .010". I am used to working within .001" of an inch in my trade so .010" kinda seems like a lot.
I called my local auto parts that has a machine shop and they are going to resurface them both for me. $40 each.
With a little luck my bolts I have on order will arrive before this weekend.
Dave
  #8 (permalink)
Old 03-04-2009, 12:30 PM
Final follow up.
The job is done. All in all I had to extract 7 broken studs below the surface of the head, six came out with an easy out and one I had to pile weld onto the end of the stud and weld it to a nut and it came right out. With some practice the welding route might be the easier way to do it. If you drill them a 90 degree close quarters drill is a must. The studs were very soft, they drilled easily with regular bits. The threads in the head had absolutely no corresion or crap in them so there was no need to chase the threads. When I installed the new grade 10.9 bolts I was able to thread them all in by hand.
The truck is noticeably quieter now. I guess I didn't realize it was louder than normal cause it was like this when I bought it.
Total cost was Gaskets-Felpro $17, Grade 10.9 Bolts $25, resurfaced manifolds $35 each, a few drills and 1 extractor about $15, and about 10 hours total of my labor which is free. Total about 140 bucks.
This went incredibly smoother than I expected. Sorry no pics.
  #9 (permalink)
Old 04-20-2009, 04:17 PM
Biggziff's Avatar
Biggziff Biggziff is offline
Biggziff is starting off with a positive reputation.
I thought I read that the old style studs are made of copper??
__________________
2005 F250 CC SRW LB Lariat V10
  #10 (permalink)
Old 04-21-2009, 06:03 AM
Quote:
The ones on mine seemed to be just plain old soft steel. they drilled easy and the weld really stuck to them as well. I think the $8 replacement studs from Ford are copper coated.
__________________
2003 Excursion V-10 Limited 4x4 in Mineral Grey. Improvements done by me: V's, Modified B's, Hellwig Rear Sway Bar, Bilstein Shocks, Red Head Steering Gear, wireless backup camera, all new exhaust manifold bolts.
  #11 (permalink)
Old 04-21-2009, 09:07 AM
Biggziff's Avatar
Quote:
Ah....so a question...can you remove a broken stud without removing the manifold? I just found one of mine (Front driver side) broken off. Ahhh the joys of the Ford Modular!
__________________
  #12 (permalink)
Old 04-21-2009, 09:35 AM
I have heard of it being done....but more than likely there are more that are "just hanging on by a thread".
__________________
  #13 (permalink)
Old 04-21-2009, 09:43 AM
Biggziff's Avatar
OK...thanks...guess I'll have to budget some time to get this one done.
__________________
  #14 (permalink)
Old 09-02-2009, 08:22 PM
AnnesLimo's Avatar
AnnesLimo AnnesLimo is offline
1999 Lincoln Navigator
My Garage
AnnesLimo is starting off with a positive reputation.
Amateur adventure?
So I have the dreaded broken bolt issue and have been quoted $1,400 to have it fixed as they have indicated the heads will have to be pulled!
After reading your posts I am curious as to your position on the difficulty level for this project. I am a mechanicly inclined self doer but this deal seamed a bit much to me.
I find it hard to believe that the heads have to be pulled to fix this but that is what I'm being told... Of course no one ever said all shops and mechanics are honest!
So in closing let me ask for some input from any members as to whether a guy like me;who can fix the washer and dryer, install a pool, build a pond, replace the brakes on any car, repair the a/c system, install radiators, water pumps, alternators and thermostats as well as replace the furnace blower motor... can I do this myself?
If I can do it myself then why do they want to charge me $1,400.00? PS: I don't weld.
Final follow up.
  #15 (permalink)
Old 09-02-2009, 09:25 PM
Biggziff's Avatar
I had 2 dealers quote me about the same price....$1000 as long as the manifolds don't crack when they remove them. I cannot imagine why someone would tell you they need to pull the heads unless they're just not willing to do them in the truck.
A local guy I use for service told me he could do it for around $500 in labor. He lets me bring my own parts.
__________________
Tags
68 , bolts , broken , exhaust , extract , ford , head , liter , manifold , problem , specs , stud , studs , torque , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
