Virginia Chapter Join Chapter, Leader:
Hood windshield washer fluid outlets clogged
Old 02-09-2009, 06:50 PM
SSG VA BEACH's Avatar
SSG VA BEACH
SSG VA BEACH is offline
Anyone ever unclog or replace these things. Mine sputter fluid out but not onto the windshield enough to be effective.
Old 02-09-2009, 07:52 PM
fordguy21's Avatar
fordguy21
fordguy21 is offline
maybe try this
https://www.ford-trucks.com/forums/3...r-clogged.html
also read about using a needle to clean out the nozzles
hope this helps
Old 02-09-2009, 07:58 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Remove the nozzles, soak them in white vinegar.
The nozzles will become clogged over time...one reason is when you wax your truck, unless you are careful, some wax will find its way into the nozzles.
Old 02-09-2009, 08:17 PM
SSG VA BEACH
Thanks for the link Adam, and the vinegar option Bill, I should have taken care of this before I painted the darn hood.
Old 03-08-2009, 04:24 PM
SSG VA BEACH
When I was out at the salv yard I got the nozzles, they pop right off with some pliers, they let me have them free to. Put them on problem solved. Easiest repair done lately.
lovemy150's
1999 to 2016 Super Duty
04-30-2017 06:27 PM
David Popp
Air Intakes, Air Filters & Ram Air
04-24-2016 02:20 PM
pappy19
1978 - 1996 Big Bronco
12-18-2015 06:29 AM
Tank77
10-23-2015 01:39 PM
FLRob
02-12-2014 11:37 PM
Quick Reply: Hood windshield washer fluid outlets clogged
