On the front, should have a Dana 44 by application.
Look at the locking hubs
It it is TTB with a 3 1/2" diameter hub is a 44
A TTB with a 4" diameter hub is a Dana 50.
If it is a straight axle with a 4" hub, it should be a Dana 60. At least for the 80-97 vintage.
im pretty sure he isnt gonna have the Dana 60 monobeam front axle, bc according to my owners maual that was only on the f350s. he has either a Dana 44-IFS or a Dana 50-IFS
Yeah, I know. They didn't have monobeam 60's in 84 anyways (not even in 350's). Only threw that out as a comparison between the 50 and 60 to cover all years.
An 80 in a F250 is not a factory option, and, it was only used in the 450/Super Duty in this body style, 10 lug, with disc brakes. That truck should have had a 10.25 under it's tail, it's entirely possible someone put LH thread studs on the drivers side. Is there a fill plug on the diff cover? And does it have a VSS on the diff?
