im building a 63 f100 and wanting to put an independent rear axle in it i found that a rear end out of a new charger will work just wondering if anybody has done this or any suggestions thanks for any input
no not sure just was wanting a nice ride with disc brakes and the wheel base is the same my frame is just narrower ill have to make mounts for the shocks and coils and subframe bolts which i can do at my job i just was wanting a nice ride with proformance cause i plan on driving this truck all over
I've seen people use such set up under their trucks so it must be worth while. Go for it. If I ever build an older truck I will install the same set up.
