FX4 shocks from the dealer
Why do you need to buy your shocks from the dealer?? Is there some kind of policy at work that says you have to do this? For tax purposes and business write offs there is no need to use oem parts. You can install aftermarket and they are still tax deductible expenses as long as they are not a performance mod (even those are deductible in some cases).
Get a set of Bilstein's and don't look back. Probably cheaper than buying them from the dealer and they are ten times the shock.
i started a shock thread, everyone says bilsteins!! which ones are good i want to replace mine but i dont want to raise the truck up, i park in a carport and the truck just fits as is down to the inch, can someone steer me in the direction of which shock kit to get? Also truck has 70k is it due for shocks?
Here are the Bilstein part numbers for your 2003 (assuming it's 4WD).
Front - F4-BE5-2818-H0
Rear - F4-BE5-C296-H0
You know Eshocks has the best price for these so far but
in my research alot of other companies are listing the
Rear - F4BE52819H0
So I went to Bilstein's homepage and they both come up as
Rear - F4BE52819H0 FORD F250 4WD SUPER DUTY R
Rear - F4-BE5-C296-H0 FORD F250/350 4WD REAR
Not sure what the difference is and there contact info doesn't have an 800#...
edit: so the F4BE52819H0 looks like the application for and F350 (scrolled further down the info pages at bilstein.com) but the heading says F250...
My "off road" shocks were shot at 40,000 miles.
2 completely shot, 1- 50%, 1- 70%.
I bought a set of Edelbrock IAS shocks and couldn't be happier. The ride is much improved, and the control is awesome.
Can't go wrong with the Bilsteins either.
Rear - F4BE52819H0
Rear - F4BE52819H0
Just so you know, for non lifted trucks, they are the same part for both the F250 and F350 in the HD shock - no difference in application.
