97 F-350 Manual Hard To Shift
Old 02-03-2009, 04:51 PM
dustbuster_26's Avatar
dustbuster_26
dustbuster_26 is offline
I've got a 97 F-350 4x4 with the 7.3 and a 5spd manual. I has a new clutch with less than 10,000 miles. It is very hard to shift even double clutching it, sometimes the gears won't align. I've replace the slave cylinder but it still seems like the clutch pedal won't fully release the clutch from the flywheel. The pedal assembly has some excess movement but not much. Just wondering if anyone out there has a the same or similar problem. Any suggestions would be appriciated.
Old 02-03-2009, 05:10 PM
live2wheel's Avatar
live2wheel
live2wheel is offline
check your clutch pedal bushing under the dash .the plastic bushing wears out and the eye and post gets worn . a little bit of play there ends up to be a lot disengageing the clutch and thats what it sounds like is happening . there is a real good fix (if thats your problem) a lil heim joint offered on e bay that replaces that whole eye and post. i think its called permanent clutch fix . i put one on mine and it solved the problems i was having.
Old 02-03-2009, 06:45 PM
Cuda_jim's Avatar
Cuda_jim
Cuda_jim is offline
x2, it's probably the bushing.
Look here:
BUSHING
Crick07
1983 - 2012 Ranger & B-Series
11-19-2013 07:06 AM
Canonman67
03-26-2011 05:04 PM
chayes01
05-31-2009 08:16 AM
kf4hoq
10-03-2006 10:41 PM
Inspector2002
01-07-2002 11:37 AM
Quick Reply: 97 F-350 Manual Hard To Shift
