Can someone help me figure out why my F150 with a 300 six is so weak in power. When I climb a big hill I have to put it to the flooor and it might get up to 35. It is a 1990 4x4 Auto. I am not sure but it seems like gas mileage has dropped alot also. Thanks
my 89 300 5speed pulls pretty good over 2k rpm. I did notice an issue not too long ago that my back 3 plugs were a little fouled compared to the front 3. Not sure if its manifold design or what.
Have you checked over the standard stuff? air filter, fuel filter, plugs/cap/rotor/timing etc.
ok, everything was done in October. new plugs ac, air filter, fuel filter,cap & wires. Check engine light is not on. Also after everything was done it still didn't seem very good I have just been living with it.
ok plugs AC
Filters- Fram
wires, cap& rotor can't remember
no codes
I did the work & changed one wire at a time
everything is in good shape
mileage 93k
