2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
LED light upgrade
Old 10-28-2010, 04:37 PM
Blacknav's Avatar
Blacknav
Blacknav is offline
LED light upgrade
Hi All,
Recently picked up a 2007 Navigator,
Am going to be changing my front park lights and turn signals to white LED lights. Problem is the turn signal will do the "quick flash" (like when a turn signal bulb is blown) because of the lower voltage of the LED.
I've fixed this on many other cars by replacing the factory turn signal flasher relay with an electronic flasher relay available from most parts stores. but don't know where it is located on
Does anyone know where the factory relay for the turn signals/hazard lights is located.
I went through my manual but couldn't find it.
Old 11-02-2010, 02:10 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
I can tell you in a couple of days when my factory manuals arrive. I just ordered factory service manuals and wiring diagrams delivered from Ebay for $33 total!!!!
Old 11-24-2010, 11:20 AM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
From what I can glean from the manuals, the turn signal is all FET control from some control module. I would assume that this means its not the old school resistance type flasher. You could easily validate this by removing a turn signal lamp and seeing if the flash frequency changes.
Old 11-25-2010, 11:07 AM
Blacknav's Avatar
Blacknav
Blacknav is offline
^ removing the bulb does cause a "hyper flash" from what I've read I belive the relay is in the "smart Junction Box" in the passenger kick panel. Going to look for the relay this weekend.
Worst case if i can't find the relay I'll just add a load resistor for each bulb
Old 11-28-2010, 10:22 AM
Baumbach's Avatar
Baumbach
Baumbach is offline
Originally Posted by Blacknav
Hi All,
OEM part numbers
Without Signal Mirror System 5C3Z13350AA
With Signal Mirror System 2L1Z13350AA
pictures
More Information for MOTORCRAFT SF633
More Information for MOTORCRAFT SF624
looks like the flasher can be changed, i do not know the location
jaym69
2009 - 2014 F150
07-24-2023 12:14 PM
BigBlueX
05-25-2015 01:25 PM
JD_F250
01-06-2015 04:33 AM
FordTruckChuck
1997 - 2003 F150
08-10-2014 10:06 PM
karichjr
09-26-2011 06:40 AM
Quick Reply: LED light upgrade
