Replace front wheel bearing 2003 F150
Old 01-29-2009, 04:41 PM
peter p's Avatar
peter p
peter p is offline
Anyone know how to replace a front wheel bearing on a 2003 F150 4x4?
What steps are involved and can it be done at home.
Old 01-29-2009, 07:16 PM
bowdog's Avatar
bowdog
bowdog is offline
I do beleive you cant just change the bearings....I think you need to replace whole hub....they are pressed in.
Old 01-29-2009, 07:25 PM
peter p's Avatar
peter p
peter p is offline
Is that hard to do?
I don't have a manual. Is there step by step instructions on how to do this?
Old 01-29-2009, 07:46 PM
thecardoc's Avatar
thecardoc
thecardoc is offline
Its mostly straight forward . Remove the axle nut (You may want to loosen this up before you jack it up if you dont have a good impact). Remove tire caliper and rotor . Then with the axle nut removed push the the cv shaft back about an inch. This gives you a little more room to at at the three bolts that hold the bearing in . Remove the three bolts. Don't forget to unplug the wire to the antilock brake harness . Now the bearing is only held rust and corrosion . I some times us a slide hammer puller at this time to nudge it out . I also coat mating surfaces with anti size during re assembly.
Expect to pay about $150.00 for the new bearing.
Old 01-29-2009, 08:02 PM
50flathead's Avatar
50flathead
50flathead is offline
Like thecardoc said. Pretty straight forward. I replaced mine about a week ago. The bearing is part of a two piece hub and serves the place of what a traditional spindle and hub would do. I did have to use a torch to heat up the hub bolts because they were rusted in place. It went together a lot easier than it came apart. 150.00 is about a cheap as you'll find them. I installed a dealer supplied unit and it had a USA made Timken bearing.
Old 01-30-2009, 06:41 AM
96f150's Avatar
96f150
96f150 is offline
Hit up the Ford Parts guy on here, He'll give you just about the best price he can..with genuine OEM parts.
Rich
Old 02-01-2009, 10:25 AM
DMch's Avatar
DMch
DMch is offline
You will find a lot of common questions on the 1st page under READ FIRST This were this link comes from how to replace your front wheel bears on a 4x4
https://www.ford-trucks.com/forums/3...f-150-4x4.html
RDockery
1997-2006 Expedition & Navigator
07-26-2015 08:07 AM
MickJaggernaut
12-16-2014 11:21 AM
stvMo
1997 - 2003 F150
11-08-2014 04:48 PM
powersmoked
10-20-2013 04:38 PM
Buckboard6-300
1999 to 2016 Super Duty
08-25-2009 03:55 PM
Quick Reply: Replace front wheel bearing 2003 F150
