Replace front wheel bearing 2003 F150
Its mostly straight forward . Remove the axle nut (You may want to loosen this up before you jack it up if you dont have a good impact). Remove tire caliper and rotor . Then with the axle nut removed push the the cv shaft back about an inch. This gives you a little more room to at at the three bolts that hold the bearing in . Remove the three bolts. Don't forget to unplug the wire to the antilock brake harness . Now the bearing is only held rust and corrosion . I some times us a slide hammer puller at this time to nudge it out . I also coat mating surfaces with anti size during re assembly.
Expect to pay about $150.00 for the new bearing.
Like thecardoc said. Pretty straight forward. I replaced mine about a week ago. The bearing is part of a two piece hub and serves the place of what a traditional spindle and hub would do. I did have to use a torch to heat up the hub bolts because they were rusted in place. It went together a lot easier than it came apart. 150.00 is about a cheap as you'll find them. I installed a dealer supplied unit and it had a USA made Timken bearing.
You will find a lot of common questions on the 1st page under READ FIRST This were this link comes from how to replace your front wheel bears on a 4x4
https://www.ford-trucks.com/forums/3...f-150-4x4.html
MickJaggernaut
12-16-2014 11:21 AM
powersmoked
10-20-2013 04:38 PM
Buckboard6-300
1999 to 2016 Super Duty
08-25-2009 03:55 PM
