fuel pump
Go on, Julie, you know this one!
Help us out here Tiger, what year is your truck? Put it in your signature so we don't have to guess! That appears to be a late model fuel pump, what kind of engine are you running? We need info like that too.
AFAIK, none of the 48 - 60 trucks with stock tanks used anything but a suction line out of the tank. I think your dad is used to newer fuel injected engines that have a return line. Your fuel pump appears to have a small recirculation line connection on the pressure side, which will have to be blocked off. So your dad is 1/2 right!
Well, kinda! For some reason maybe I mixed apples and oranges from another post and was thinking flathead - and this just ain't anything close to a flathead fuel pump - as you know (oh stop laughing)....DOY!
I would venture to say that with the pressure relief outlet and threaded fuel outlet, this was used on a high pressure/flow application and maybe an engine with early fuel injection. 302 or 351W maybe. or possibly 327/350 Chev? Definately for a newer (70s or early 80s I'm GUESSING) application. Maybe Tiger will let us know what he's got in his truck so I will look REALLY dumb.
Even my Carter high pressure/flow fuel pump on my 390 uses hoses and clamps.
Too many distractions lately.......
Julie
Julie
They said the engine was a 1969 block. Julie, you were right, it is a 302. I installed a '69 Mustang tank, and the sending unit that came with it is the one I was referring to.
I would guess that it's the correct fuel pump. It is the one that they sent me with the engine. But of course, there was nothing with it explaining it. So if I need to run a return line to prevent vapor lock, anyone have suggestions on how to run one through the tank? Or is LEckart right and I need to block off one of the outlets...and how is that done?
I suspect the vender assumed that you had a newer vehicle with a return line. I have a 78 460 in my 54 and it doesn't have the return line. It just has the line from the tank and outlet to the carb.
You might check with a good parts store that is familiar with people working on swapping engines into older vehicles to see if there is a different pump that would work for your application. Many of the NAPA stores have people that can help with this.
Tell them you want a fuel pump for a 302 that is using a 69 mustang fuel tank with no return.
Fuel Pump
That pump is designed for a tank return , to prevent vapor lock. Plugging the tank return doesn't always work so well , sometimes causing over pressurization of the carb . You would be better off with a two line pump thats designed for your tank system. A pump for a 60's or early 70's engine would work better.
Have A Good Day ----- Hotwrench
I haven't quite solved the problem yet. I was taking all things into consideration, and found something on jegs that would work (as long as I have 2 3/4" between the tank and bed...but don't know how much room I have yet. But I was also thinking, is there a way that I could put some sort of "T" device behind the fuel pump that would pump the fuel straight back into the line? That would be much cheaper than buying the jegs device.
Here's a diagram of what it would be like....
Next, if I do have to get the jegs device, does anyone know the distance on a 50 F-1 from the frame to the top of the bed. I'm lazy and don't want to drag the bed all the way to the garage to measure it, then take it back down to storage. I will just add that distance to the distance between my frame and where my tank sits to know if i have enough room. I will attach a pic of the jegs device so you can see what I am talking about.
Put a fuel pressure gauge in the extra line (mounted in the engine compartment). It will add 5 HP! Use as much steel line as possible.
Honestly, I'd be surprised if a pump with two lines is any different internally. The extra return line has an orifice about 1/16"-dia. inside it to restrict flow of liquid gas. Vaporized gas can whistle right thru it, but liquid flow is pretty small.
