Clutch - Which brand internal Slave Cylinder
Well - it would appear that based on searches, the internal slave cylinder is a common fail part. I have a 92-96 model F250 with the internal slave, and I think cold weather contributed to it's failure. Appears to be leaking fluid and the clutch pedal sticks to the floor.
I'm seeing the same symptoms that this thread suggested: https://www.ford-trucks.com/forums/6...ld-clutch.html
So a few questions - is there a recommended replacement - what manufacturer is best?
What other parts should I replace? I'm thinking about getting the full kit with the cylinders, flywheel, throwout bearing and clutch plate. I think I read a thread that suggested upgrade to an 11" clutch plate from the 10".
Any suggestions appreciated.
I really want to minimize the need to do this internal slave again. Wish there was an external conversion
Thanks.
Ph: (909) 877-6800 Fax: (909) 877-6803
This is a great opportunity to repair or remedy a few things while the transmission is on the floor.
1. Get the dealer specified clutch components (all of them)
2. Inspect rear main seal for leaks, seepage
3. Great opportunity to replace u-joints while the shafts are down
4. Upgrade to synthetic fluid
An ounce of prevention.....
Tim
Tim
aikensj
08-09-2015 01:37 PM
jkschneider
21
01-25-2013 12:42 AM
colesdad
05-03-2010 09:24 PM
