Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-21-2009, 09:51 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Conversion on 1st batch
Completed first batch. titrated @ 5, used 1600 grams of KOH with 7 gallons of methanol & 32 gallons of dewatered oil. Ended up with a little over 30 gallons of Bio and over 8 gallons of glycerine. Will distil the methanol off both the glygerine and the bio tomorrow... Anyway does this sound ok so far?
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 01-22-2009, 06:46 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Sounds good to me! Did you try the Varnquest 3/27 test to see if you got full conversion?
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 01-22-2009, 10:15 AM
Rushmore X's Avatar
2003 Ford Excursion
Plan on doing that today after distilling off the methanol
__________________
  #4 (permalink)
Old 01-23-2009, 10:45 AM
Rushmore X's Avatar
2003 Ford Excursion
Methanol mostly in Glycerine?
Distilled the bio yesterday, looks pretty good, even before we wash. After 1.5 hours @ 145 degrees we only got about a little over a half gallon of methanol. It appears most of the methanol is in the glycerin, we will distill that later. Is this normal?
thanks
__________________
  #5 (permalink)
Old 01-23-2009, 04:48 PM
1935 Ford pickup
Most of the excess Methanol IS in the glycerol. Are you going to waterwash, or use Magnesol?
__________________
  #6 (permalink)
Old 01-23-2009, 06:45 PM
Rushmore X's Avatar
2003 Ford Excursion
Well... I'm trying to talk my partner into drywashing but... Water isn't any fun to use when it's Zero. I'm hoping that he'll see that too. Anyway converting the 60 gallon cone to dry wash would be easy...
__________________
  #7 (permalink)
Old 01-24-2009, 09:21 PM
Knotwild Knotwild is offline
Garage is empty, add now
Knotwild is starting off with a positive reputation.
I suggest running the 3/27 test before cooking off any methanol. If you do have a failure and the fuel is unwashed and not de-methed, you can heat and add 1.4g/l of KOH and 25-35 ml/l of methanol and re-react.
A couple of biodiesel friends and I have also had some bad batches lately and found it to be the quality of the KOH. I had to move my base amount up to 9.9g/l, corrected for 90% purity KOH. That appears to have solved the incomplete conversion problem.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #8 (permalink)
Old 01-25-2009, 09:12 AM
Rushmore X's Avatar
2003 Ford Excursion
I think that I used 91% purity in calculation. Thanks for the tip, the batch is still sitting in the reactor, we had a artic front go through and temps around zero, so waiting to warm back up (Tues supposed to be above freezing again) Will forward this info to my partner.
__________________
  #9 (permalink)
Old 01-25-2009, 09:32 AM
The KOH purity will be on the bag, so different supplies will probably vary. Making biodiesel always presents new things to learn and new problems to solve. I sure am glad we don't have that kind of cold here in GA!
Two other things I have learned are:
Pre-treating your oil by heating it and mixing in approximately 20% (by volume) of the glycerin drained from the previous reaction will significantly clean up your oil, remove water (but not if present in excess), and lower the titration. Just heat the oil to about 120F, add glycerin, mix for a couple of hours, and drain the glycerin back off. Then titrate and react as normal. My oil usually titrates 5-6, but lowers to 0.5-1.0 after doing this.
Don [(fabman) thanks Don] gave me this tip: After the reaction is complete as determined by the 3/27 test, demeth the biodiesel and let it settle for 24-48 hours. Soap and glycerin that would normally need to be washed out will settle and you can decant the fuel. Using this method has allowed me to cut my Magnesol use to 2-3g/l.
I decant the fuel and mix Magnesol with a paint stirrer for a couple of hours, settle overnight and filter. I bought a bag filter housing from Fryer to Fuel that allows me to use 1 micron absolute filters and it has been one of my best investments. I have few biodiesel pictures at: Biodiesel - a set on Flickr
__________________
  #10 (permalink)
Old 01-25-2009, 09:43 AM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Gun-Driver is starting off with a positive reputation.
I like to use this calculator for my batch's it allows you to adjust for purity.
Matts Recipe Calculator
  #11 (permalink)
Old 01-25-2009, 06:19 PM
Rushmore X's Avatar
2003 Ford Excursion
I'm assuming that the 20% is not de-methed, or do you distill it than re-introduced? thanks
__________________
  #12 (permalink)
Old 01-26-2009, 10:44 AM
Rushmore X's Avatar
2003 Ford Excursion
Also this is 20% of the Glycerine that drops out, not 20% of the volume of oil right?
Suppposed to be back up in the 40's in a couple days, so plan on finishing this batch and starting the next... thanks
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
