1994 Ford F150 Radiator Tank Cracked
The top plastic radiator tank is cracked on my '94 F150, 300 Six on top of the hose inlet. I tried repairing it with some putty like Billy Mays advertises, it worked for a few days and began leaking again. I patched it from the inside and on the outside, let it sit for 24 hours so it looks like this is not an option.
Is there any other way to stop the leak, if not I guess I'll be buying a radiator.
About 2 years ago the E4OD transmission went out, when the transmission place rebuilt it they bypassed the radiator and added a cooler. When I get my new radiator can I put the transmission lines back in the radiator and remove the external cooler?
Thanks,
Lil Josh
Thanks,
Lil Josh
Don't get a new one. Take it to a guy who does radiator repair. It'll be less than half the price. It's always the hot side tank that breaks. Hot water enters one side and cooled water exits the other. The hot side tanks are what typically crack. A radiator guy will put you a new tank and they're supposed to be better plastic than the OE. I've had 4-5 rebuilt over the years and have never had to do one a second time yet.
The added extra cooler does much more cooling than the radiator does all by itself. The only trans cooling you get from a radiator is via a very small brass heat exchanger in one of the tanks. Water flows over it and cools it. That extra cooler you've got on there is an major upgrade. It provides 10-20 times the cooling than the radiator. That cooler is a major component of a towing package if you buy a truck with a towing package. They're not cheap either so I'd leave it as is. My 94 3/4 ton Suburban has a trans cooler on it that is 2/3 the size of the radiator and it has a giant radiator.
Lil Josh
06-15-2014 08:42 PM
John90
1997 - 2003 F150
08-27-2013 02:28 PM
LARIAT 85
07-10-2013 09:38 AM
Lil Josh
16
11-08-2008 06:24 PM
