Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-09-2009, 09:40 PM
05F350CC's Avatar
05F350CC 05F350CC is offline
05F350CC is starting off with a positive reputation.
Diesel Engine Heater
Hi All,
My son told me about this diesel engine heater that runs on fuel from your vehicle's fuel tank and will keep your coolant and oil warm and can also be tapped into your vehicle cab heating system. This will allow you to keep your engine and cab warm without plugging in at extreme cold temps (which we have had plenty of here in Alaska recently!)
Does anyone know anything about these? What are they called, who makes them and how good are they? Any problems? My poor truck just doesn't like these -45F temps and anything I can do to give the old girl a little help is of interest to me.
  #2 (permalink)
Old 01-09-2009, 10:14 PM
mhoefer mhoefer is offline
mhoefer is gaining momentum as a positive member of FTE.
Look up Webasco's website, they make diesel powered heaters which can be used to heat your engine coolant, the cab ect. They use them on highway trucks to keep them warm during winter instead of running the truck while sleeping. I beleive they make smaller units for RVs and auto's but they are expensive. They use about a litre of fuel per hour. I would think the solution for a pick up is using the block heater and possibly an oil pan heater for both transmission and engine, which would really help your truck for startups and faster warm up and be more cost effective. If you search this site, you will find references for these oil pan heaters and you can wire it and hte coolant heater to a single 20 amp Marinco plug you can plug in your truck and both will be heated. We have some of these temps at times too and the solution is plugging in. But I have been entertaining the addition of oil pan heaters and the Marinco plug. My truck has been started at these temps many times but it sure seems hard on it. Heating the oil, using synthetic oil, haveing a good winter front on the truck also help for sure.
__________________
Mike
2005 F350 CC 6.0/5 sp/3.73 LS Auto Lariat
Bullydog Outlook Monitor, Tonneau, Toolbox, High Idle Mod, iPod Mod, dfuser Coolant Filtration Kit
27 ' Jayco Jayflight TT
(old Truck, sold at 132,000 Km, 2000 F350 S/C 5.4/4 sp Auto XLT 4.10s )
  #3 (permalink)
chevenstein's Avatar
chevenstein chevenstein is offline
chevenstein is starting off with a positive reputation.
I've seen these - they're some sort of military surplus oil fired miniature boiler. Output is about 30K BTU/hr and as far as I can tell they haven't been made new in years, but come up on eBay every so often and go for $200-$500. They use 12V power for the ignitor, fuel pump, and burner blower.
__________________
1990 F350 7.3IDI 4x4 ZF5
1962 F250 flatbed 4x4 Detroit Diesel 453, Clark 5spd OD
Used to have:
1989 F150 300I6 M5OD 2wd
1988 F250 7.3IDI 4x4 ZF5
1989 F350 7.3IDI 4x4 ZF5 (parted out)
  #4 (permalink)
Old 01-09-2009, 11:41 PM
broncobran68's Avatar
broncobran68 broncobran68 is offline
2009 Ford F-150
broncobran68 is starting off with a positive reputation.
we have a webasto on our detroit at work. i've never used it but it looks nice and i'm sure you could adapt it.
__________________
'09 F150 SCREW FX4. 2.5" AS Leveling kit. Line-x. 35" Toyo M/Ts on 18x9 Moto Metals
'68 BRONCO. 5.5" lift, 35s, 289 EFI, rollcage, durabak interior
  #5 (permalink)
Old 01-10-2009, 10:23 PM
Cheventstein, webasto are not surplus and are not old. They are on heavy heavy truck practically that runs up here in Canada. They come in several sizes, large enough to heat a 18 litre highway truck and cab, large enough to heat a container, small enough to heat a small RV or Boat. Not cheap but a great solution. There are other makes, I saw a web posting on this site just recently but can't remember the name. I think buying and installing on a F350 might be a pretty tricky and costly job. But I am sure a price at a heavy truck shop could be written down if you asked. Probably $2 grand in total I would bet.
__________________
Mike
  #6 (permalink)
Old 01-11-2009, 08:48 AM
Quote:
I didn't know someone still made these, the ones I'm thinking of are literally as I described - metal drums painted olive drab with water, fuel, and electrical connections and US Army markings. They basically miniature fire tube boilers with 12 volt controls and every so often someone will list some on eBay.
Either way, it's a neat idea.
My bigger problem is running out of power - when it gets really cold (< 0) my batteries will need to be charged or heated to get the truck running. Forget about it if it's gelled up. I've been contemplating putting a PTO box on the transfer case with a hydraulic motor on it driven by a small bed mounted gas engine - virtually unlimited cranking capability without having to worry about overheating the starter or killing the batteries.
__________________
Used to have:
  #7 (permalink)
Old 01-11-2009, 09:23 AM
mustang_guy mustang_guy is offline
mustang_guy is starting off with a positive reputation.
Im a truck driver for a living and I have a Webasto in my Peterbilt.
The webasto only heats your coolant not your oil.
It heats the coolant in your block only so the block is warm and easier to start the motor in the cold. It will not make your heating in your cab warm when you first turn your truck on and your coolant temp will still be at zero. The webasto is only a starting aid.
Some of you were talking about the webasto cab heater above. Thats a different unit itself, its called a bunk heater. It will keep your sleeper warm but it is a seperate unit form the coolant heater. Both work off the diesel from the tanks.
  #8 (permalink)
Old 01-11-2009, 01:14 PM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is starting off with a positive reputation.
Here is the web site
BlueHeat® Coolant and Air Heater Selection
They are not just for big trucks.
They are not government surplus.
And they work great.
Takes about 6-8 hours to install.
Keeps coolant at 150'F.
circulates the coolant and keeps windows defrosted.
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4 moose lites
Mobil-1 Turbo diesel truck oil
fuel filters every 10,000 miles
AstroStart auto start
98 gal Transfer flow tank
Rhino liner on the rockers
Wabasto-Blue heat
MBRP turbo back duels w/ no CAT
  #9 (permalink)
Old 01-13-2009, 11:52 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 is gaining momentum as a positive member of FTE. Dean88 is gaining momentum as a positive member of FTE.
A buddy of mine who was stationed in Alaska for a while claims he brought a small metal bucket of sand and would pour a few cups of diesel in it and would light it, then he had some kind of vent lid on it, and would set it right under his oil pan, and it could keep it warm for a few hours.
__________________
1992 F250 351W E4OD 3.55 Sterling
1988 F250 7.3 C6/underoverdrive 4.10 D70
1980 F100 300 3spd 2.73
1987 F150 302 T18 4.10 (RIP)
American by birth, Southern by the grace of God, Libertarian by choice!!!
  #10 (permalink)
Old 01-14-2009, 04:33 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.
Quote:
Why don't You jsut buy some new batteries?
Much cheaper.
I've started My trucks in -35*F without any starting aids.
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
http://www.ford-trucks.com/user_gall...149391.520.390
  #11 (permalink)
Old 01-14-2009, 07:21 AM
tjc transport's Avatar
tjc transport tjc transport is offline
is it friday yet??
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
Quote:
i know a guy that used to do that with his ford diesel backhoe.
until a fuel line broke and the fuel leak dripped into the firepot, and the fire got larger, and burnt the backhoe to a crispy critter!!
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #12 (permalink)
Old 01-14-2009, 07:25 AM
Quote:
Much cheaper.
My batteries are less than two months old and tested to over 1100 cranking amps each when I installed them. Good suggestion though. I've also cleaned the connections a replaced some terminals. The only thing I haven't done is replace the starter (it's not that old), but maybe that's what I need to do.
__________________
Used to have:
  #13 (permalink)
Old 01-15-2009, 03:20 PM
mnmwhit's Avatar
The Blue heat from Wabasto is really neat. When I go snowmachining and there is noplace to plug in I still get into a warm truck.
__________________
Wabasto-Blue heat
  #14 (permalink)
Old 01-17-2009, 02:29 PM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
Average battery output at 0 degrees F is below 50%. More like 40%. This is why it's so important to have your batts fully charged and in good condition at these temperatures.
Batt warmer's also do wonders as well...
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / 5er
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
  #15 (permalink)
Old 01-17-2009, 03:09 PM
mnmwhit's Avatar
And that makes a good point towards buying above average batteries. I am using the Sears Platnum Batteries which are a Gell Cells.
__________________
Wabasto-Blue heat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
