How to replace F-Series 4WD Actuator 1997
There's a plastic cover over the actuator. Remove the 3 bolts attaching the cover. The actuator is held in place by an "E-clip". Slide the clip off and work the actuator out of the hole it mounts in. Remove the vacuum lines, noting the position of the colored lines. The difficulty in getting it out of the mounting hole is relative to the corrosion/mud/grease that has accumulated over the years. Installation is the reverse. You're sure it's the actuator and not a broken vacuum line?
View the Technical section of my Gallery for photos of the vacuum actuator system.
https://www.ford-trucks.com/user_gal...&albumid=26547
You can also search my and others posts for troubleshooting and discussions on the subject.
Re: Acuator replacement
Thanks Steve:
I have plenty of vacuum at the acuator motor when it is in 4wd. In fact when I pulled the vacuum line off the acuator to verify vacuum, and then put the vacuum line back on, it went right in to 4wd. But when I go back to 2wd & then try to shift bact to 4wd it does not go in. I got it locked into 4wd right now with cable ties so I can snow plow. But I got to get a replacement acuator. Looks like the diafram is sticking.
Bob
Bob
They're about a hundred bucks from the Ford vendors here, I think.
Th!nk Parts Guy/FTE Parts Guy
Silver State Ford Parts Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
Paredez
1997 - 2003 F150
06-09-2012 09:03 PM
