2004 5.4 timing problem
Old 01-05-2009, 04:44 PM
sterlingdan's Avatar
sterlingdan
sterlingdan is offline
On my 2004 (f-150 5.4 new style) the camshaft sprocket bolt came loose at 75,000 miles. The cam phaser broke apart. I removed the valve cover and replaced with a new sprocket and cam phaser, however I believe I've got the timing off by a tooth or more. The engines runs again, but runs bad at an idle and on the road. When I unhook either cam sensor the engine actually runs smoother but has reduced power.
Since I don't have the timing cover off, I can't align the chain to the crank pulley. I need to find a diagram or picture that shows where the passenger side sprocket should be when the engine is at top dead center.
Does anyone have a picture, or know where it should be?
Thank you!
Steve Bassen
2004 - 2008 F150
77
06-14-2018 09:50 AM
BFTUFF
1997 - 2003 F150
07-07-2014 07:33 PM
nw4wheeler
Modular V8 (4.6L, 5.4L)
06-26-2013 07:14 PM
vincedo
1999 to 2016 Super Duty
11-14-2011 11:30 AM
Quick Reply: 2004 5.4 timing problem
